F134 Hurricane - JeepForum.com
post #1 of 13 Old 12-05-2013, 09:44 AM Thread Starter
Dtsouth2
1963 CJ5
F134 Hurricane
Any suggestions for a better carb for a F134 Hurricane?
Dtsouth2 is offline
post #2 of 13 Old 12-05-2013, 07:47 PM
Newbjeep
1972 CJ5
An amc 304 ha
Newbjeep is offline
post #3 of 13 Old 12-05-2013, 07:55 PM
seabass1858
1983 CJ7
I rebuilt my carter yf about 5 years ago and got new throttle shaft bushings for it also. The major adjustment on it is the fuel metering rod but the rest is cake. Do not settle for the cheap solex replacement or you will be sorry.
seabass1858 is offline
post #4 of 13 Old 12-06-2013, 01:43 PM
strvger01
1966 CJ5
back in the day, there were some 2bbl carb adapters made for the 134F head. i had one once. not easy to come by, but they are out there.
1966 CJ5A, mods are coming
1966 Wagoneer, bone stock
strvger01 is offline
post #5 of 13 Old 12-06-2013, 02:29 PM
seabass1858
1983 CJ7
weber makes one come to think of it http://www.carburetion.com/Weber/Dat...0/%20WILLY%27S
post #6 of 13 Old 12-06-2013, 02:54 PM
chromegrille
1947 CJ2A
old IH Scout or Ford Bronco Holley 1bbls
chromegrille is offline
post #7 of 13 Old 12-06-2013, 03:50 PM
CJ51973
CJ51973's Avatar
Old AMC Jeeps had 1 barrels too. That stock carb on the 134 is a good carb. Use to wheel with a guy who had one and it ran good when tilted too
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
post #8 of 13 Old 01-13-2014, 12:59 PM Thread Starter
Dtsouth2
1963 CJ5
So should I get my orginal rebuilt or should I go with a new two barrel
Dtsouth2 is offline
post #9 of 13 Old 01-13-2014, 02:03 PM
Balvar24
1979 CJ7
Rebuild the original, but do it correctly. Worn shafts can let air leak in.
"Work hard, rock hard, eat hard, sleep hard, grow big, wear glasses if you need 'em."
Balvar24 is offline
post #10 of 13 Old 01-13-2014, 02:10 PM Thread Starter
Dtsouth2
1963 CJ5
Thanks! Any ideas where to get the kit?
Dtsouth2 is offline
post #11 of 13 Old 01-14-2014, 10:10 AM
Balvar24
1979 CJ7
Napa? Beware any rubber/plastic parts. Some of the old stock on the shelves may not be compatible with new gas. Best to find something without too much dust.
Balvar24 is offline
post #12 of 13 Old 01-14-2014, 01:59 PM
strvger01
1966 CJ5
the engine isn't set up for unleaded gas anyway with the original valve train. just get a kit and rebuild it with the parts in it. by the time those rubber and/or plastic parts succumb to the gas, your engine will be screaming for a rebuild or replacement anyway.
post #13 of 13 Old 01-14-2014, 02:02 PM
Balvar24
1979 CJ7
It's not the unleaded fuel that kills the rubber, its the ethanol. Some guys mix a litte aviation fuel in to overcome the lead issue.
Balvar24 is offline
