F-134 Hurricane in CJ3a - success! - JeepForum.com
post #1 of 6 Old 02-27-2011, 06:23 PM Thread Starter
jbcarney
1951 CJ3A
I finally found a Holley 1904 carb to put in my Cj3a. Somewhere in its' history some PO put an F-134 in this low hood CJ3a flatty. With the Carter carb, it was several inches too tall which is why the Cj3B has the 'high hood' design...adding about 6" to the hood.
This carb gives me just over an inch or so below the hood line to create an air horn.
The only other 'mods' I had to do was use 3 gaskets to get the throttle arm to clear the engine block and put a small dent the valve cover to make room for the float bowl. You can see that in the picture below.
I'll also have to cut down the breather on the top.
Anywho, after looking a long time on the web, (including JCWhitney taking a month to tell me they were still looking for a core) I finally found a rebuilt from RockAuto.com. The had a rebuilt 1904 for $120 (+$40 core charge). That's nothing compared to new Holley 1904 carbs which were $450. Since I didn't pay that much for the jeep itself, wasn't gonna go there.
The great news is that the engine runs like a champ, nice and smooth. It does blow some smoke, so I'll have to chase that next, but things are looking up!
John - 1951 CJ3a
http://thejeepproject.blogspot.com
"Life is hard. Life is harder when you're stupid."
jbcarney is offline
post #2 of 6 Old 06-25-2011, 07:05 PM
HackedUpJeep
holley 1904
My oil stick hits on the fuel bowl of the holley, so I was thinking about shortening it. I don't see your oil stick in the picture, just curious how you got it to fit or is it located somewheres else?
thanks Matt
HackedUpJeep is offline
post #3 of 6 Old 06-27-2011, 06:04 AM Thread Starter
jbcarney
1951 CJ3A
Holley 1904
Well, you're right in that it's not in the picture. The engine I have does not have the tall oil tube, but rather about 3"inches of small tube where the base of what you're describing would be, so I didn't have to adjust for that.
John - 1951 CJ3a
jbcarney is offline
post #4 of 6 Old 06-27-2011, 11:22 PM
HackedUpJeep
hey brother, thanks for the clarification. I ended up shortening mine, easy fix. what did you endup doing for the air cleaner horn. I dont have any of the original cleaners, so I have to start from scratch.
Matt willys mb with an f134
post #5 of 6 Old 06-28-2011, 05:39 AM Thread Starter
jbcarney
1951 CJ3A
I haven't focused on the air horn just yet. Like you, I don't have any of the original parts and have to start from scratch.
I'd be greatly interested in any ideas you come up with or any info you might find.
-John
John - 1951 CJ3a
jbcarney is offline
post #6 of 6 Old 12-29-2013, 07:18 PM
gssmith1986
1950 CJ3A
Did you come up with an air filter solution
I have the same setup: F-134 with Holley 1904 under a CJ3A Hood. Right now the carb is running naked, and I'm curious if you found a solution?
gssmith1986 is offline
Cj3a Milspec Jeep CJ Forum 3 03-08-2011 05:44 PM
Flat tow a cj3a? stinsonj Jeep CJ Forum 2 02-18-2010 03:57 PM
CJ5 vs cj3a flatfender. Which is better? Renegade_Rick Jeep CJ Forum 12 08-14-2008 07:31 PM
Where buy CJ3A radiator? farmjeep50 Jeep CJ Forum 1 07-17-2008 06:57 AM
cj3a swaps blackyj Jeep CJ Forum 1 05-19-2005 06:43 PM
