EZ Wiring Question - JeepForum.com
post #1 of 9 Old 11-23-2012, 01:43 AM Thread Starter
xnodesirex
1978 CJ7
EZ Wiring Question
Been slowly re-wiring my '78 CJ7 from scratch with an EZ-Kit. I got the larger of them (21 circuit) for future expansion, but wiring up the engine is driving me a bit crazy due to the crappy diagrams.
I've checked JH amazing diagrams, and they've helped in a few earlier steps, but this one has me puzzled. I'm planning a full write up on how to install the harness just in case anyone else tries this endeavor.
There is a fat red wire labeled (solenoid power). I have that running to the same side of the solenoid as the battery/alternator, and currently the jeep will turn over/run.
BUT.
There is no 'sense' wire for the alternator. There is an excite wire (white), which is run to the #1 spot on the alternator.
Also, there is a red wire (not fat, maybe 12g?) that is labeled "alternator power." Where does this go?! Hooking up a volt meter to it tells me that it receives constant voltage, so I'm a bit stumped.
xnodesirex is offline
post #2 of 9 Old 11-23-2012, 06:14 PM
248107
1983 CJ7
Just giving you a courtesy bump.A write-up would be great.Sure would eliminate a lot of questions.Good Luck
248107 is offline
post #3 of 9 Old 11-24-2012, 12:38 AM Thread Starter
xnodesirex
1978 CJ7
Pretty sure I've encountered most/all of them thus far -- and I haven't even started the dash yet! Haha.
Best way I could ever imagine spending a week of vacation around the holidays
post #4 of 9 Old 11-25-2012, 03:31 AM Thread Starter
xnodesirex
1978 CJ7
ttt
anyone?
post #5 of 9 Old 06-04-2013, 07:29 PM
altier04
1980 CJ7
dont know if you still need help but im hooking one up on my 78' also and my alternator had a post on the back where that red wires hooks up. it also has a 2 wire plug tucked on the motor side kind of hiding underneath.
altier04 is offline
post #6 of 9 Old 06-04-2013, 07:35 PM
clmelt1
1978 CJ5
I have the same harness I'm my cj5 with a 304, I used this diagram with the diagram that came with the kit. How this helps.
https://docs.google.com/file/d/0Bxel.../preview?pli=1
clmelt1 is offline
post #7 of 9 Old 06-04-2013, 08:17 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
How does the EZ harness go through the firewall? Stock type bulkhead connector, or their own unique one?
I asked a ref if he could give me a technical foul for thinking bad things about him. He said, of course not. I said, well, I think you stink. And he gave me a technical. You can't trust em. -
Jimmy V
Pacfanweb is offline
post #8 of 9 Old 06-04-2013, 08:34 PM
burley
1976 CJ5
How does the EZ compare to Painless? I'll be rewiring mine soon. Don't mean to hijack the thread.. BUMP!
burley is offline
post #9 of 9 Old 06-04-2013, 10:43 PM Thread Starter
xnodesirex
1978 CJ7
Don't know how EZ compares to painless, other than a few hundred less expensive.
Everything had labels, which was a big plus, BUT required you to figure out lengths, terminations, and sometimes where things went. Old CJ wiring diagrams were a lifesaver, but I waited until the last minute to lock things down. After I ran the wires in the harness, I went back and ran my relays (Horn Relay, Headlight Relay), added independent grounds back to a bus bar for all of the headlights, horns, taillights, starter, solenoid, alternator and dash/gauges. So it probably was wire overkill, but at least I have complete confidence that I'm not going to randomly encounter things not working. Haha.
To one of the earlier questions - it has its own bulkhead connector, but was SMALLER in the fuseblock than the historical. Similar mounting studs (so no new holes), but I took a piece of aluminum to fill in the gaps.
