exhuast leak? - JeepForum.com
post #1 of 2 Old 01-18-2002, 01:25 PM Thread Starter
Hino01
Post exhuast leak?
I have a 75 CJ-5, 304 CID, 3 speed manual. What I am curious to know why does it not have any noise idling but when you romp on it it sounds like I am driving a open header stock car. I have headers on it. I have looked around the seams and gaskets for a leak. The only place there is any thing wrong is on the #8 exhaust port. The header bolt is missing or snapped. It doesn't sound like a typical leak but more like something is loose. Conrod or wrist pin maybe? It's only on the right side.
Hino01 is offline
post #2 of 2 Old 01-23-2002, 09:24 PM
MeandmyCJ
Post
If you've got a header bolt missing, you've got a leak. It will sound like an open pipe when you 'get on it'. With my Heddman fenderwell headers (unmodified), if one bolt backed out 1/2 turn mine would leak aroung the standard gaskets. This was especially prevalent on number 7 & 8 cylinders, since they got most of the stress from the free hanging headers. You should be able to remove the other header bolts, drop down the header and use an easyout to remove the broken bolt. It should come out easily. If there's enough sticking out, you should be able to get a vice grip on it and back it out. I modified my Heddman headers by grinding down the little TIG welds arount the ports and made the surface flat across the entire header. I also drilled out the header bolts and used mechanics wire to keep them from backing out. A little copper spay-on gasket (brushed on) is all I use for gaskets. Check out http://www.headersbyed.com/hdrs.htm#...BChevFlngs_pic for an example of how the flanges should look after they are prepped. Good luck
'83 CJ5 w AMC304
Last year of the CJ5
MeandmyCJ is offline
CJ V8 Exhuast Question laserxenon Jeep CJ Forum 0 10-10-2008 03:08 PM
304 exhuast leak baystrucksalvag Jeep CJ Forum 1 08-18-2008 04:57 PM
exhuast??? bowenboy Jeep CJ Forum 21 10-08-2007 12:15 PM
where can i buy a exhuast clamp omanalansanjr Jeep CJ Forum 7 06-19-2007 03:07 PM
77 cj7 360 exhuast??'s redhat6161 Jeep CJ Forum 2 10-15-2003 08:28 PM
