exhaust still getting really hot!!! - JeepForum.com
post #1 of 16 Old 10-19-2009, 04:21 PM Thread Starter
CarolinaAndy
1976 CJ5
Hi. I posted a week ago about my exhaust mans getting up to 500 degrees and causing a "hard start while hot" condition (carb getting too hot as well). I checked timing and it was at 8 deg which is spec for the 232. I was told somthing about an exhaust riser? no idea what i'm doing i guess.
What do I look for? could a gasket leak cause an overheat of the manifold? HELP!!!!
-Andy
CarolinaAndy is offline
post #2 of 16 Old 10-19-2009, 04:22 PM Thread Starter
CarolinaAndy
1976 CJ5
is there a better source on the 232 than this sh!tty Hanes manual?
post #3 of 16 Old 10-19-2009, 04:27 PM
scottymac62
1979 CJ7
Yes, It's called the Jeep CJ FSM.
'77 CJ-5 Renegade 304 / T-150, Dana 20, 30/20 axles, Aussie Locker in the Dana 30, American Racing 15x10 Outlaw II's, 33" Dynapro M/T's" ,Optima Battery, TeamRushed + Summit Racing CDI ignition, FlowKooler water pump, Edelbrock Performer Intake Manifold, Holley 4160 390cfm, Herculiner, Silver Ceramic Coated Hedman Hedders, Flowmaster 40's.
Warn PowerPlant HD 12K Winch, Dirtworx front and rear bumpers.
scottymac62 is offline
post #4 of 16 Old 10-20-2009, 09:38 AM
CJhollic
1980 CJ7
How are you determining that your manifold and carb are getting too hot? Are you sure you dont have a dragging starter?
Weber 32/36 DGEV,
4" Suspension Lift , 1 " body lift
8000 lb Winch,
ViAir Onboard Air
TeamRush ignition upgrade with MSD 6a CDI
Dual Batteries
KC Daylighters
Cold Air Intake
Lock-Right Lockers
Yukon 1 piece axles
Custom Bumper& Swing Out Tire Carrier
Mile Marker Hubs
Chevy Blower Upgrade
1500 lb airbag suspension
Floor mounted gun rack (2 guns)
CJhollic is offline
post #5 of 16 Old 10-20-2009, 04:57 PM Thread Starter
CarolinaAndy
1976 CJ5
I'm using a temp gun and scanning the whole motor for hot spots. and it starts up like a champ unless I run it for a long while and shut it off for about 20 minutes.
post #6 of 16 Old 10-21-2009, 01:18 PM
CJhollic
1980 CJ7
I supect you problem is probably a bad starter, bad battery are defective wiring.
Weber 32/36 DGEV,
8000 lb Winch,
ViAir Onboard Air
Dual Batteries
KC Daylighters
Cold Air Intake
Lock-Right Lockers
Yukon 1 piece axles
Mile Marker Hubs
CJhollic is offline
post #7 of 16 Old 10-21-2009, 08:00 PM Thread Starter
CarolinaAndy
1976 CJ5
the motor turns over fine though. It will just keep cranking without firing off.
post #8 of 16 Old 10-21-2009, 08:20 PM
popascj7
1976 CJ7
Have you done a compression test on it when it's hot?
popascj7 is offline
post #9 of 16 Old 10-22-2009, 10:34 AM
CJhollic
1980 CJ7
sorry, I thought you meant it was turning over slowly.
Weber 32/36 DGEV,
8000 lb Winch,
ViAir Onboard Air
Dual Batteries
KC Daylighters
Cold Air Intake
Lock-Right Lockers
Yukon 1 piece axles
Mile Marker Hubs
CJhollic is offline
post #10 of 16 Old 10-22-2009, 10:46 AM
Mike Romain
Well vapor lock after a hot shutdown is the reason they started putting the return lines and two outlet filters on them. If you have the proper filter and return line, make sure the return is at the top of the level sitting filter or the gas will blow back to the tank.
Mike
Mike Romain is offline
post #11 of 16 Old 10-22-2009, 07:22 PM Thread Starter
CarolinaAndy
1976 CJ5
There is an adaptor plate that the webber carb sits on that has a pinched off line coming out of it. Is that supposed to be the line to prevent vapor lock?
[IMG]C:\Users\Oberdier PC\Pictures\2009-10-14[/IMG]
post #12 of 16 Old 10-22-2009, 07:26 PM Thread Starter
CarolinaAndy
1976 CJ5
[IMG]C:\Users\Oberdier PC\Pictures\2009-10-14\020.JPG[/IMG]
post #13 of 16 Old 10-23-2009, 05:38 AM
John Strenk
John Strenk's Avatar
1976 CJ5
You will have to use the "manage picture option" to upload that picture off your hard drive or put it someplace on the internet picture site for us to see the picture.
Are all your cylinders firing? sometimes a cylinder will be dead and the fuel and air mixture will get pumped into the exhaust and start to burn there.
John Strenk is offline
post #14 of 16 Old 10-23-2009, 06:50 AM
Mike Romain
As John mentions, use photobucket or something to store your photos and post the img link here,
The gas filter is the return. It has two outlets, the center outlet goes to the carb and the top metered outlet goes to the return line,
Weber eh.... Well there are some nasty 'weber' clones out there like the '34' that run way too rich as they come and also run way too rich without a fuel pressure regulator on them. They need new jets and a regulator to run if you are lucky. This 'gent' fred wrote a paper worthy of a doctorate thesis on making one work: http://www.jeepforum.com/forum/f8/we...-258-a-631105/
Maybe that will be of use to you?
Mike
post #15 of 16 Old 10-23-2009, 07:10 AM
algmmech
1974 CJ5
500 degrees is not too hot at an exhaust manifold. I've seen AIR systems bring temps above 900. I didn't read you other post, what I know so far is the engine cranks over fine when hot, but takes a long time before it actually starts. May be vapor lock, caused by a sticking heat riser. The heat riser is in the lower part of the exhaust manifold, just above where the exhaust pipe bolts on. The heat riser is a valve that has a counter weight and bi-metallic spring. When the spring heats or cools it will allow the valve to open or close. The valve will restrict exhaust in the manifold when cold to help keep the carb from freezing. Make sure you can rotate it, it should turn about 90*.
Now it may not be vapor lock. Is there anything you do than helps it start, like pumping the gas pedal or holding it to the floor. Have you checked spark? After shutting off the hot engine, look down the throttle bore, is fuel running out the venturi nozzle? Is the choke open fully? How long of cooling does it need to make it easier to start.
Give us as much information as possible, Once again 500* is not too hot. You may or may not be on the right track with the vapor lock theory.
mostly stock 74 cj5, 258, t14, d20, d44 & 30.
I'm a member of PETA.
People Eating Tasty Animals
algmmech is offline
Exhaust - Seal between Heat Valve and exhaust pipe Woolys_CJ7 Jeep CJ Forum 1 01-22-2010 07:07 AM
cj-7 I6 4.2 exhaust zachblamercj7 Jeep CJ Forum 4 08-23-2008 06:02 PM
Considering New Exhaust Face Jeep CJ Forum 3 07-15-2008 08:00 AM
need an exhaust for an 83 cj tphin Jeep CJ Forum 1 07-06-2008 06:45 PM
sbc exhaust cj5one Jeep CJ Forum 1 01-12-2007 08:05 AM
