Exhaust smoke and no idle Weber 34 conversion - JeepForum.com
post #1 of 3 Old 03-14-2007, 07:39 PM Thread Starter
daoliv
I have not had a bunch of time to spend working on my CJ but I did finish my Weber carb conversion. It still has a hard time starting and will not hold an idle and also there is smoke coming from the exhaust which is dark gray. Dies when I lift my foot off of the gas. When I start it, it starts right up but will not stay on unless I press on the gas pedal. I checked all of the connections even held the choke plate open and it runs the same. Today it backfired once through the carb. Could this be a fuel pressure problem. I know it has a new fuel pump on it since the last on had a hole in the diaphram. I am thinking the pressure is to high since I did not put a fuel pressure regulator on it. I really do not want to mess with the fuel mixture yet or the ide screw.
Any help from anyone that knows what might be happening please help. I would like to get my baby back on the road.
Thanks,
David
daoliv is offline
post #2 of 3 Old 03-14-2007, 08:01 PM
Bard
Backfiring is timing. I would set your timing, get a timing light and set it right. The Webers like 4 to 5 lbs of fuel pressure, a regulator does that. I know they prefer the holley FPR, I can't remember what model it is, someone else can chime in, Factory is 7lbs of fuel coming in. Check your fuel filter as well or just go new.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #3 of 3 Old 03-14-2007, 10:42 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
yep you need a FPR and a return line back to the tank hooked up..Check your timing and for vacume leaks..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
Originally Posted by Me
"offroad it, and wave then you might understand"
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..
Mr.Crowley is offline
Exhaust smoke on my 360! BG33 Jeep CJ Forum 2 01-09-2010 01:41 PM
weber 34/34 black smoke android7105 Jeep CJ Forum 2 06-07-2009 08:51 AM
Idle Mix and Idle Speed on Weber jennandal Jeep CJ Forum 2 01-28-2008 07:41 PM
White smoke, timing, idle, etc. HELP! jennandal Jeep CJ Forum 14 10-28-2007 08:06 PM
Weber Conversion JMSCJ5 Jeep CJ Forum 5 02-24-2003 07:46 AM
