exhaust smell while driving - Page 3 - JeepForum.com
post #31 of 44 Old 06-20-2013, 08:34 PM
gmgreen
1983 CJ7
Stupid question, how do you check the exhaust for a leak?
gmgreen is offline
post #32 of 44 Old 06-21-2013, 02:28 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Block the exhaust with your gloved hand over the outlet.
If the engine dies, it's ok. IF it keeps running you have a leak....
Still, running with the top off with the exhaust running straight out the back will have the fumes sucked right back behind the windshield.
John Strenk is online now
post #33 of 44 Old 06-21-2013, 08:25 AM
BobBuford
Yes, where the exhaust exits out the back is important but you need to tune. I drive open air/bikini top and no doors but even after I had purchased mine, with the exhaust exiting behind the left rear wheel, I still smelled like exhaust because it needed tuning. After adjusting the carb, spark, timing and fuel pressure regulation, I no longer smell like exhaust, nor smell it. My kiddos would definitely let me know if I did. I know I have a leak under the seat but just haven't had time to fix it. Even with that I don't detect it.
First learn about your engine and it's systems by whichever method and then get it tuned correctly. It will help the performance.
BobBuford is offline
post #34 of 44 Old 06-27-2013, 01:03 PM
gmgreen
1983 CJ7
Thanks John.
gmgreen is offline
post #35 of 44 Old 07-05-2013, 07:52 AM Thread Starter
kp33
1978 CJ5
Originally Posted by 82JeepCJ7 View Post
Due to the aerodynamics of a brick, the air circulates over the back, creates a low pressure area that draws the exhaust into the cab area. Re route the exhaust out to the side and I bet the smell goes away.
So can I add a 90 degree tip to my existing exhaust, thanks.
kp33 is offline
post #36 of 44 Old 07-05-2013, 08:19 AM Thread Starter
kp33
1978 CJ5
Another question to your theory, how come this doesn't happen in my 2005 f150, my exhaust sticks out the back and my kids ride in the bed of the truck all the time and never smell like exhaust. Thanks
kp33 is offline
post #37 of 44 Old 07-05-2013, 08:30 AM
Neuner-9R
As BobBuford said, Tune your Jeep! :
Neuner-9R is offline
post #38 of 44 Old 07-05-2013, 11:59 AM Thread Starter
kp33
1978 CJ5
78 cj5, no doors or top, after I drive it I smell like exhaust. Anything I can do, is something wrong, or is it normal because I'm all open. Thanks.
Gonna go with exhaust to the side
kp33 is offline
post #39 of 44 Old 07-05-2013, 12:08 PM
LumpyGrits
Where to the side?
I run mine out the back corner as per OEM. I also keep my Jeep tuned and I NEVER get any smell.......Even when sit'n at idle on the trail or in traffic.
LG
LumpyGrits is offline
post #40 of 44 Old 10-25-2013, 06:34 AM Thread Starter
kp33
1978 CJ5
Originally Posted by LumpyGrits View Post
Where to the side?
LG
I got my pipe turned behind my driver side back tire and I still smell of exhaust. Went to my local jeep place and they said I should have cut it back so the pipe is under my jeep to where I can't see it and point it down. Any thoughts. Thanks.
kp33 is offline
post #41 of 44 Old 10-25-2013, 08:28 AM
WindKnot
1977 CJ7
Well, firstly, I'm sorry that didn't fix it.
Second, where the guy at the dealership said to put it is NOT where Jeep, the folks who built it put it. They put it in the corner where many of us suggested, and how many of us eliminated the fumes. The Service writer is either an overlooked genius, or as I suspect, mistaken. Aerodynamics; how do they work?
Here's hoping it's a chap easy fix.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #42 of 44 Old 10-25-2013, 01:15 PM Thread Starter
kp33
1978 CJ5
Yeah, not sure why,now what?
kp33 is offline
post #43 of 44 Old 10-25-2013, 05:01 PM
TRUVOL
Check your shifter boots. If their torn they need to be replaced. That was my issue.
TRUVOL is offline
post #44 of 44 Old 10-25-2013, 05:05 PM
JayCO
1982 CJ7
My transmission boot is torn, and I have the same issue. Need to replace it.
JayCO is offline
