exhaust smell while driving - Page 2 - JeepForum.com
post #16 of 44 Old 06-14-2013, 03:18 PM
WindKnot
1977 CJ7
At the point in life mechanically where you are, either find a really good mechanic who understands carburetors inside and out, or get a friend who understands these things to show you.
If you want to understand, I think you're at the point where someone needs to "show" you on a carburetor how to adjust it. But to be honest, there are tools required to do it right and it takes experience.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #17 of 44 Old 06-14-2013, 03:20 PM Thread Starter
kp33
1978 CJ5
Originally Posted by LumpyGrits View Post
Learn how to 'read' your spark plugs
http://www.ngksparkplugs.com/tech_su...qs/faqread.asp
LG
Will check them out, thanks.
kp33 is offline
post #18 of 44 Old 06-14-2013, 03:24 PM
LumpyGrits
YES, to the need of a 'hands-on' teacher.
LG
LumpyGrits is offline
post #19 of 44 Old 06-16-2013, 01:21 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
If you don't have a catalytic convertor on it, put one on. I know many people talk them down (emissions crap, they plug up, cost you power, etc.) but I had mine off for a short time but I couldn't stand the stink anymore. I put it back on and it has a much tamer of a smell now. I was wanting to replace it as it was showing signs of deterioration, and I did notice a little loss of pep from that deterioration, but until I swap the engine in a couple years, this will get me by. I still have plenty of power even with the 258. I will be putting a new one on when I run the new exhaust for my V8.
Rick
Cutlass327 is offline
post #20 of 44 Old 06-16-2013, 03:33 PM
WindKnot
1977 CJ7
Unless it was made for California, his Jeep didn't come from the factory with a catalytic converter.
WindKnot is offline
post #21 of 44 Old 06-17-2013, 03:09 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
My 78 did. I do not believe it was a CARB vehicle. Either way, adding one would help the odors.
Rick
post #22 of 44 Old 06-17-2013, 03:23 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Well Wait.
Where does the exhaust exit on his jeep?
If it is straight out the back then he would be sucking it back towards him.
Particularly with the top off.
Ask me how I know.....
John Strenk is offline
post #23 of 44 Old 06-20-2013, 12:48 PM Thread Starter
kp33
1978 CJ5
Well Wait.
My exhaust sticks out the back on the drivers side, sticks out from the back maybe 2 inches or so, thanks.
kp33 is offline
post #24 of 44 Old 06-20-2013, 01:16 PM
82JeepCJ7
1982 CJ7
Due to the aerodynamics of a brick, the air circulates over the back, creates a low pressure area that draws the exhaust into the cab area. Re route the exhaust out to the side and I bet the smell goes away.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #25 of 44 Old 06-20-2013, 01:19 PM
gily25
Do you only have the rear window up/out? open a front window and you probably won't smell it anymore. If you don't have drain plugs and you have a leak before the axle it might be getting in through there.
iPhone app user; excuse typos...thanx.
gily25 is offline
post #26 of 44 Old 06-20-2013, 01:26 PM Thread Starter
kp33
1978 CJ5
No top or doors
kp33 is offline
post #27 of 44 Old 06-20-2013, 01:40 PM
LumpyGrits
My exhaust exits right rear corner as OEM.
No smell EVER.....
My sons '5' w/401 exits both rear corners.
No smell EVER.....
LG
post #28 of 44 Old 06-20-2013, 02:24 PM
2Xtreme
2Xtreme's Avatar
1979 CJ7
Originally Posted by Cutlass327 View Post
...Either way, adding one would help the odors.
Not if he has a leak and/ or improper routing of exhaust....
2Xtreme is offline
post #29 of 44 Old 06-20-2013, 04:13 PM
Patter
1981 CJ5
Mines out the drivers side.
"I have a very strict gun control policy: if there's a gun around, I want to be in control of it."
Patter is offline
post #30 of 44 Old 06-20-2013, 05:24 PM
WindKnot
1977 CJ7
Has the OP checked his plugs or looked for leaks? This thread has run for a week and no status report.
WindKnot is offline
