exhaust smell while driving - JeepForum.com
post #1 of 44 Old 06-14-2013, 08:10 AM Thread Starter
kp33
1978 CJ5
78 cj5, no doors or top, after I drive it I smell like exhaust. Anything I can do, is something wrong, or is it normal because I'm all open. Thanks.
kp33 is offline
post #2 of 44 Old 06-14-2013, 09:22 AM
sanctified
I know that the exhaust pipe has a seam right under my driver seat on my '83 CJ7. Mine isn't sealed so I do smell my exhaust but when I've got the top off I don't notice it. Top on though is a different story. I need to seal it up but just haven't yet. If you smell exhaust I would guess you have a leak somewhere that if found could be patched up.
2013 JK (see info on left)
SOLD: 1983 CJ7
Utah Jeep Crew #178
sanctified is offline
post #3 of 44 Old 06-14-2013, 09:34 AM
LumpyGrits
IF your exhaust exits out the back.....
NO, you have a leak somedangplace.
You might be run'n on the 'rich' side also if you can smell it.
LG
LumpyGrits is offline
post #4 of 44 Old 06-14-2013, 09:40 AM Thread Starter
kp33
1978 CJ5
What's weird is I don't really smell it when driving, but I smell it on me after.
kp33 is offline
post #5 of 44 Old 06-14-2013, 09:40 AM Thread Starter
kp33
1978 CJ5
What does running on the rich side mean.
kp33 is offline
post #6 of 44 Old 06-14-2013, 09:45 AM
LumpyGrits
Rich fuel mix.......
LG
post #7 of 44 Old 06-14-2013, 09:48 AM
LumpyGrits
Exhaust is get'n inside he cab.......
Look for leaks/cracks, This is NOT safe for you.
LG
post #8 of 44 Old 06-14-2013, 09:52 AM
sanctified
Are you sure its exhaust? Could it be that your hoses connected to the charcoal canister have come undone or are not there? I had a few loose hoses there also that made my clothes and the garage stink.
SOLD: 1983 CJ7
Utah Jeep Crew #178
post #9 of 44 Old 06-14-2013, 10:01 AM Thread Starter
kp33
1978 CJ5
No idea to be honest with you.
kp33 is offline
post #10 of 44 Old 06-14-2013, 12:17 PM
WindKnot
1977 CJ7
Your exhaust should be routed to the left rear corner of the Jeep behind the wheel. It should NOT be routed straight out the back. If it is the slip stream will pull it back into the Jeep. When in motion a low pressure area is created behind the vehicle. (Ever hear of "drafting"?) Putting it out the side allows the slipstream to pull it away from the Jeep.
You should check the whole system or leaks too, and there are other sources for gas oders such as the canister under the hood.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #11 of 44 Old 06-14-2013, 01:31 PM Thread Starter
kp33
1978 CJ5
LG
Using 87
kp33 is offline
post #12 of 44 Old 06-14-2013, 01:41 PM
WindKnot
1977 CJ7
"Rich" means too much fuel in the fuel to air ratio in the carburetor. "Lean" means not enough fuel in the ratio. The grade of gas has nothing to do with it. If it's too rich, some of the fuel doesn't get burned and you can smell it.
WindKnot is offline
post #13 of 44 Old 06-14-2013, 01:42 PM
LumpyGrits
THIS
LG
post #14 of 44 Old 06-14-2013, 01:55 PM Thread Starter
kp33
1978 CJ5
So how do I check it Thanks
kp33 is offline
post #15 of 44 Old 06-14-2013, 02:06 PM
LumpyGrits
Learn how to 'read' your spark plugs
http://www.ngksparkplugs.com/tech_su...qs/faqread.asp
LG
