Exhaust manifold Paint - JeepForum.com
post #1 of 10 Old 01-07-2014, 07:52 PM Thread Starter
cdt540
1983 CJ7
I am in the process of putting back together my rebuilt motor. I had the exhaust manifold blasted and trying to decide whether to paint it. I actually like the appearance blasted and un-painted. Other than appearance is there any reason why you need to paint it?
Thanks
Chris
'83 CJ7 (258 4spd)
cdt540 is offline
post #2 of 10 Old 01-07-2014, 09:02 PM
UBERK
1976 CJ7
Not in my opinion. Just use hi-temp paint such as VHT.
Ill be painting the OE manifolds on my 401 similar to what Matt1981CJ7 did here....
UBERK is offline
post #3 of 10 Old 01-07-2014, 09:40 PM
dg6772
I used a ceramic header coating from Summit Racing on my ramshorns. Still looks good after a year on and off road.
Dave in Muskegon
dg6772 is offline
post #4 of 10 Old 01-07-2014, 10:19 PM
capt205
1983 CJ7
I painted mine black, and the intake aluminum. Both with high temp paint.
Almost a year later...still looking good
capt205 is offline
post #5 of 10 Old 01-08-2014, 05:11 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I'm a fan of the VHT paint.
I think the key is to "cure" the finish by baking it , per the instructions.
My manifolds have 5K miles on them, and still look like the day I painted them.
Matt
Matt1981CJ7 is offline
post #6 of 10 Old 01-08-2014, 06:36 AM
FLynes
De Oppresso Liber
FLynes's Avatar
1976 CJ5
Matt
Does the wife know you're using her oven to cure your parts?
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
Black Wellington Vinyl Bench Seats
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #7 of 10 Old 01-08-2014, 06:43 AM
Matt1981CJ7
1981 CJ7
It's all a matter of timing the curing for when the Warden is gone.
Surprisingly, the fumes weren't bad at all.
Matt
post #8 of 10 Old 01-08-2014, 07:15 AM Thread Starter
cdt540
1983 CJ7
Thanks for the feedback! I am excited to finally get the CJ running.
cdt540 is offline
post #9 of 10 Old 01-08-2014, 09:52 AM
holliewood61
holliewood61's Avatar
1981 CJ7
Matt
I had to buy my own oven to put in my garage basement for curing the vht and baking small powder coated bits. Somehow the warden always knew when I used hers. I did luck up and find one that would hold a 15x12 wheel though
08 WK bone stock
00 WJ daily driver
99 TJ mostly stock 97 TJ cheap jeep
81 CJ7 very little stock
60 CJ5 tore down
holliewood61 is offline
post #10 of 10 Old 01-08-2014, 10:19 AM
cjjon7
1983 CJ7
+1 I used the VHT paint after blasting, no primer and they are holding up well.
cjjon7 is offline
