Exhaust Manifold Heat Stove - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Exhaust Manifold Heat Stove
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueSavvy Aluminum Gas Tank SkidFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 07-14-2014, 12:19 PM   #1
BlkCJ7Laredo
BlkCJ7Laredo's Avatar
Hi all,
I installed a new exhaust manifold many years back and never kept the heat stove off the original. Does anyone know if you can get this piece separately anywhere or if anyone has an old manifold laying around would they be interested in selling the stove? The piece circled in yellow.
Thanks!!
'85 CJ-7 Laredo currently under construction.
My Rebuild/Restoration Thread, In Progress
BlkCJ7Laredo is offline   Reply With Quote
Unread 07-14-2014, 12:37 PM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
I have seen them for sale new. They go along with headers.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is online now   Reply With Quote
Unread 07-14-2014, 12:57 PM   #3
numbersix
1979 CJ5
I'm also interested as I run all the stock equipment on my CJ-5. I've searched high and low, couldn't even find a used one.
1979 CJ-5, mostly stock.
2001 XJ, DD / offroad.
numbersix is offline   Reply With Quote
Unread 07-14-2014, 01:09 PM   #4
Mike Romain
I was looking at some link for headers for sale and saw them.
Mike
Unread 07-14-2014, 04:10 PM   #5
keith460
Jeep. There's Only One
keith460's Avatar
Yeah, the originals are near impossible to find. I was still able to use mine on my 84 but if the time comes where it rust out completely, I'll take it off and have it made from our company's Water-Jet expert. In stainless too.
1984 CJ-7 Renegade
Restoration Thread:http://www.jeepsunlimited.com/forums...d.php?t=434226
keith460 is offline   Reply With Quote
Unread 07-14-2014, 04:45 PM   #6
FLynes
FLynes's Avatar
1976 CJ5
I've got a spare, but I'm saving it for the day when my other one is done. Like Keith said, they're hard to come by, but I do remember seeing an aftermarket variant for sale. If you use the mighty Google, you should be able to find it.
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
Black Wellington Vinyl Bench Seats
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
Grammar Test
FLynes is offline   Reply With Quote
Unread 07-14-2014, 05:39 PM   #7
bdatkins
1978 CJ5
Obviously this isn't original, but seems like it could be made to work.
http://www.summitracing.com/parts/edl-65951
You might also talk to BESRK. Doesn't seem like it would be that difficult to fab.
bdatkins is offline   Reply With Quote
Unread 07-20-2014, 07:21 PM   #8
BlkCJ7Laredo
Looky what I found... A couple years ago a buddy gave me a bunch of Jeep parts he had in his shed, and until today I had forgotten about them... I was rummaging thru some stuff in my lean-too out back and ran across not one, but TWO exhaust manifolds both with the heat stoves still attached and in good condition! Also an intake with the original studs and nuts for the BBD carburetor which I already extracted one before I snapped the picture.. Plus also found an OEM spare tire snubber bracket that attaches to the rear corner of the tub.
What's the best way to go about attaching the heat stove to my manifold once I get it off one of these and cleaned up? They are originally riveted on but I've never used that type of rivet before, only pop rivets...
Unread 07-20-2014, 07:36 PM   #9
FLynes
FLynes's Avatar
1976 CJ5
Mine actually uses the exhaust manifold bolts, to secure it. Maybe you could secure it with hose clamps? It wouldn't be pretty, but it would work.
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
Grammar Test
