exhaust manifold heat riser - JeepForum.com
post #1 of 4 Old 10-07-2002, 07:18 AM Thread Starter
dpoliver
Question exhaust manifold heat riser
the idea behind this thing is to let the engine warm up and then the flap open to allow the exhaust gas to flow to the system...right?
mine seems to be stuck...have to turn it with a wrench...
once the engine is warm it makes a terrible rattling sound...
should i be working on freeing it up or repalcing it...or do i even need this thing?
dpo
86 cj7 4.2l i6,torqueflite 904 at,
GM hei ignition, weber,
31 in a/t tires, so far...
dpoliver is offline
post #2 of 4 Old 10-07-2002, 04:14 PM
jadams68
jadams68's Avatar
Yeah, the manifold heater (under the carb) is used to heat the fuel mixture up when you run the engine below 160 degrees.
It's controlled by a switch on the manifold that goes to relay.
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #3 of 4 Old 10-07-2002, 06:55 PM
werewolf7111
well you dont "need' it to run but it does help by preheating the fuel
but if you had to wrench turn it- its normally frozen and replacement is the cure
werewolf7111 is offline
post #4 of 4 Old 10-10-2002, 06:03 AM Thread Starter
dpoliver
well it wasn't the riser....
took that out...freed up the egr while i was at it...
but the knocking remains...only once the engine heats up...
manifold gasket ,.... bad exhaust valve....
any ideas...
dpo
dpoliver is offline
heat riser/air cleaner question rodjr Jeep CJ Forum 4 08-27-2011 05:30 AM
Heat riser temp spring on 78 4.2 exhaust manifold Cutlass327 Jeep CJ Forum 2 12-15-2009 11:29 AM
Heat riser in exhaust manifold - which way's open? Cutlass327 Jeep CJ Forum 2 04-26-2009 02:51 PM
Blocking or plugging heat riser hose bobweiser Jeep CJ Forum 8 06-27-2007 03:17 PM
heat riser? Bubba Ray Jeep CJ Forum 13 04-23-2007 04:31 PM
