Exhaust Manifold 82 CJ7 4.2L - JeepForum.com
post #1 of 4 Old 08-05-2011, 07:55 PM Thread Starter
BraveDave
It's Just Math!
BraveDave's Avatar
1982 CJ7
Hey guys, I'm new to this. This is my first Jeep. 82 CJ7 4.2L 5 speed. Manual brakes and steering.
I have a leak at the exhaust manifold and need to replace the gasket. Looking at the service manuals, it seems straight forward. A couple of questions. Anything I should be concerned with?
Should I replace the manifold with a header (recommendations?) and can I remove the emissions stuff? (smog pump, etc). I'm in Texas and they don't check emissions on this old of a vehicle.
Can I remove the catalytic converter?
Any advice would be appreciated.
Dave
BraveDave is offline
post #2 of 4 Old 08-05-2011, 08:24 PM
CALOcruiser
CALOcruiser's Avatar
1978 CJ7
I went through the same decision last year. I could have fixed my leak with a new gasket and manifold (around $180 from morris auto). My manifold was too rusted to salvage and possibly cracked. I opted to go headers and a new Weber carb, rather than learn to fix my carter bbd. It was may more expensive and a pain to get all the after market stuff to fit right. However, I think I have a better setup with more power and easier to tune. I also cleaned all the emissions stuff off to make a nicer looking engine bay. Mine didn't work anyways, wouldn't pass. The pain was really more due to custom stuff from clifford not mating to stock parts well. You will also have to redo your exhaust for headers, but I was doing that anyways.
If you are happy with your performance and don't want to open a can of worms, just fix the gasket .
CALOcruiser is offline
post #3 of 4 Old 08-14-2011, 08:42 PM Thread Starter
BraveDave
It's Just Math!
BraveDave's Avatar
1982 CJ7
Thanks. After taking off the manifold, I've decided to replace with a header. The smog pump also broke. The bracket holding bolt area cracked in half. So I'm removing that. Just have to figure out what vacuum lines need to be removed or plugged. Should I take off the EGR?
post #4 of 4 Old 08-14-2011, 09:02 PM
CALOcruiser
1978 CJ7
I figured that would happen. Most of my stuff was already broken or non-functional, the rest became that way when I tried to take it apart.
What carb are you running? I removed the EGR, and all the vacuum lines that weren't needed for my Weber. The Carter will likely require more. Can't help you there. However, I don't have power brakes or a functional charcoal canister right now. Only thing that needed vacuum on my motor is the distributor advance and the PCV.
Intake Manifold connected to Exhaust manifold - delete? attworth Jeep CJ Forum 14 01-19-2012 03:51 PM
Exhaust Manifold to Exhaust Pipe Studs NelsonATC Jeep CJ Forum 3 07-25-2011 08:43 PM
258 exhaust manifold help qpinet Jeep CJ Forum 0 10-02-2010 11:51 PM
'83 CJ7 Exhaust manifold shadetree Jeep CJ Forum 9 06-03-2009 11:23 AM
V-8 Exhaust Manifold jksull Jeep CJ Forum 5 04-06-2009 07:41 PM
