Engines options - JeepForum.com
post #1 of 3 Old 07-03-2013, 07:57 PM Thread Starter
nevaga
Engines options
Can I use a 4.0 6 inline on a t14 transmission ?
If yes do I need adapters?
If no, can you give me options for 6 cilinder and transmission for a 1975 cj5?
Thanks
nevaga is offline
post #2 of 3 Old 07-03-2013, 09:04 PM
only in a jeep cj
Yes. The bell housing will bolt up to the 4.0 Some small details are match the flywheel used to the starter used (same engine type combo), change out the pilot bushing to match the larger T14 input shaft diameter, One engine block mount bracket has one bolt that will need a bolt changed out to a metric bolt, Wiring harness blend of course, 4.0 YJ throttle cable needed, etc
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #3 of 3 Old 07-03-2013, 09:21 PM Thread Starter
nevaga
Thanks
nevaga is offline
