Which engines interchange? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Which engines interchange?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBds fox ipf 2.0 racing series shocks now available at rockSpartan Lockers FREE SHIPPING Excellent Prices
Unread 02-22-2008, 07:33 PM   #1
Hillbillyd
1980 CJ5
Can you jerk a 258 engine out and bolt in a 304? I know the engine mounts would need to be different, but other than that is it the same bellhousing pattern?
Hillbillyd is offline   Reply With Quote
Unread 02-22-2008, 10:37 PM   #2
jp360cj
1977 CJ7
yes, the bellhousings are the same. In fact any AMC v8 will bolt up (post '70).
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal, Home built 4x4 tube bumpers, KC Daylighters
73 CJ6-Future project
jp360cj is online now   Reply With Quote
Unread 02-23-2008, 05:37 AM   #3
Bubba Ray
What are the donor vehicles for V8 swaps into an 84 CJ with T176 trans?
Bubba Ray is offline   Reply With Quote
Unread 02-23-2008, 06:32 AM   #4
bluwtrsurfr
bluwtrsurfr's Avatar
I am not sure on exactly all vehicles, but I know wagoneers had AMC V8's...hope that helps a little
Will
81 Jeep CJ5 4" lift, 33" Mickey Thompson Baja Claw tires.
bluwtrsurfr is offline   Reply With Quote
Unread 02-23-2008, 08:10 AM   #5
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Shoot.. Waggies, Full size Jeep trucks, AMC Muscle Cars.. any AMC V8 is a pretty easy swap.
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Unread 02-23-2008, 08:21 AM   #6
Hillbillyd
1980 CJ5
Cool. Mine has the TF999 transmission I believe, and my 258 has weak oil pressure. I thought if it ever scattered on me I'd just drop in a v8. Funny thing is, the engine runs super smooth. No knocks or strange noises. But even with a new mechanical gauge, it only holds 20-25lbs going down the highway, and 0 at idle. From the posts I've read it seems alot of people have that problem. I think the v8 swap is how I'll fix mine. Thanks
Unread 02-23-2008, 09:15 AM   #7
HackFabrication
1976 CJ5
IMO, you are not gaining much by swapping in a stock 304 for your stock 258. Grab a 360 if you want an AMC V8.
Otherwise, sit down and 'run the numbers' on rebuilding/replacing your I6, versus converting to V8 status.
"In the end...It's all Hack."
HackFabrication is offline   Reply With Quote
