Engine Wont Shut Off - JeepForum.com
post #1 of 3 Old 10-19-2009, 01:00 PM Thread Starter
glsimmons1
1974 CJ5
I have a 74 CJ5 that I am putting in a DL7127m altenator (1 wire with excite terminal). I have installed it and am having some major issues!!! I have the main alt wire hooked up to the battery. The #2 terminal wire is hooked up to the horn relay and the #1 is hooked up to the + side of the coil. I can not shut the engine off once started. I did not hook up a diode, is this the problem.
glsimmons1 is offline
post #2 of 3 Old 10-19-2009, 01:41 PM
JeepHammer
Running On Empty...
1973 CJ5
Check your PM.
It's the diode missing that is letting the engine run on.
To test this, disconnect the two wire plug from the side of the alternator and try to shut the engine off.
If it shuts off the way it's supposed to, then you need a diode.
Since you are familiar with the diode in the harness, I assume that you have the directions for install, where and how to install...
If not, let me know and I'll reprint instructions.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #3 of 3 Old 10-19-2009, 02:15 PM Thread Starter
glsimmons1
1974 CJ5
Let me get the Diode and I will let you know if it works. I have drained the battery somehow and am currently recharging it!
Thanks for the help!
73 CJ5 ignition won't shut off engine !! Lilnuts Jeep CJ Forum 14 10-11-2013 12:18 AM
Drivers Door wont stay shut! kickingprop Jeep CJ Forum 6 05-08-2010 10:51 AM
Starter wont shut off Mike1084 Jeep CJ Forum 4 07-01-2009 07:48 AM
Engine still runs...still won't shut off SQF1 Jeep CJ Forum 4 04-20-2009 07:56 AM
engine sputters when shut off Jason Cramer Jeep CJ Forum 3 07-23-2007 12:52 PM
