Engine trouble - JeepForum.com
post #1 of 4 Old 10-12-2003, 09:49 AM Thread Starter
v75vette
Question Engine trouble
The past couple of times i've driven my 85 CJ7 I've gone to turn it off and taken the key out yet the engine is still "puttering"(it's running but not full out like it would with it turned on.). It's getting gas from somewhere. It sat there for about 20 seconds doing this before it finally turned off. Any body know what causes this or how to fix it?
v75vette is offline
post #2 of 4 Old 10-14-2003, 08:11 AM
Aphelion79
Aphelion79's Avatar
Check the electronics on your carb. not sure exactly what is causing it but i believe there is some sort of device that cuts fuel when the key is off.. the drivers manual covers this Dieseling problem, i'll see if i can find out any more information for you when i get home tonight.
Aphelion79 is offline
post #3 of 4 Old 10-18-2003, 12:53 AM
jeeprme1
Sounds like it's "deiseling". Does it idle at a high RPM?
jeeprme1 is offline
post #4 of 4 Old 10-21-2003, 04:03 AM
Scrambler82
Scrambler82's Avatar
1982 CJ8
I'm with jeeprme1, a quick way to stop the deiseling is to shut the engine off while you let the clutch out a little or if auto shut the engine off in gear.
Get it fixed quick because it can cause damage to your engine.
Some causes can be carbon in the cylinders, timing, even a vacuum leak.
Sorry I can't be more specific.
Good Luck,
Scrambler82
Do it right the first time !
Scrambler82 is offline
304 Engine Trouble bills79jeep Jeep CJ Forum 8 09-02-2009 06:36 AM
304 V8 engine trouble help 75CJLevi Jeep CJ Forum 1 08-29-2009 11:27 PM
258 engine trouble TxJeeper20 Jeep CJ Forum 3 06-06-2009 10:02 AM
engine trouble nichols077 Jeep CJ Forum 5 03-05-2007 04:14 PM
Engine trouble Tuts Jeep CJ Forum 9 11-18-2003 07:16 PM
