Engine / Tranny switch Quesiton - JeepForum.com
post #1 of 2 Old 08-16-2002, 12:54 PM Thread Starter
kev1
Question Engine / Tranny switch Quesiton
This might have been asked before, but all well.
Does anyone know if I take the GM-151 and SR-4 out of my 1980 CJ7 and replace them with a 1984 258 and T-5 if I will have to change the length of the drive shafts? What about anyother changes?
Thanks,
Kevin
kev1 is offline
post #2 of 2 Old 08-16-2002, 10:55 PM
cjdriver
cjdriver's Avatar
The only other things you should have to change is the engine mounts and possibly the radiator for better cooling. If the 4 was in an '80 then it should have had a D300 TC so the tranny from the '84 should bolt right up to it.
You also may have to change the clutch, since the four probably came with a hydraulic clutch and the T5 would not have had one. So you might have to put in a whole new clutch system.
Jim Sykes
motorsports photography
cjdriver is offline
Wiring Taurus fan, Quesiton on Solenoid.. ncmx1 Jeep CJ Forum 3 10-20-2009 05:38 PM
Thoughts on Engine Switch for 81 CJ7 Drsafety Jeep CJ Forum 10 03-25-2009 01:03 PM
Engine Kill switch? SeaWulf Jeep CJ Forum 11 02-27-2009 09:07 PM
Engine Won't Let Go Of Tranny... ollietonk Jeep CJ Forum 16 11-04-2006 10:56 AM
Back light switch for '73 CJ5 Warner T15 tranny qualityhardware Jeep CJ Forum 2 05-11-2003 11:28 AM
