engine and tranny combo ... will it fit? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > engine and tranny combo ... will it fit?
GEARSHADE Pocket Tops in stock and available at ROCKRIDGE Artec JK Under Armor BellypanEngo winches available at www.rockridge4wd.com! Free shipp
Unread 06-27-2014, 09:05 PM   #1
ceej7
going to look at engine / tranny combo tomorrow. 4.2 six with ba/10 5 speed with 80k.runs and shifts good .guys puttin v8 in instead. question 1. heard this trans is a dog. if so dont want it, but will put on c list. question 2. I have a 258 in my 85 cj7 now with t176. any adapters needed to make it bolt up? or is one 258 the same as another? question 3. if trans is decent will my dana 300 bolt up ? the guy wants 150 bucks for combo ,and my engine has a lot of blow by so is this the kick *** craigslist buy of the week or what? any help or comments appreciated.
ceej7 is offline   Reply With Quote
Unread 06-27-2014, 09:26 PM   #2
firegod33
1977 CJ5
The BA10 is a colossal pos. I'd stay away from it. The 258 is essentially the same throughout production. There are some minor differences that can be easily overcome.
Earth first... We'll Jeep the other planets later.
firegod33 is offline   Reply With Quote
Unread 06-27-2014, 09:42 PM   #3
Mean Max
Don't poke the bear
Mean Max's Avatar
Stop being so nice! It's WWWAAAAAAAYYYYYY worse than that!
It's a boat anchor.
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Unread 06-27-2014, 09:53 PM   #4
ceej7
well thats what i read on some of these posts, but the engine is what i really need. any ideas what i need to bolt this engine to my tranny. any other issues?
Unread 06-27-2014, 09:58 PM   #5
Mean Max
Don't poke the bear
Mean Max's Avatar
Other than verifying that the pilot shaft bushing is the proper one for your T176, it should be a bolt-for-bolt swap.
Max
Unread 06-27-2014, 10:09 PM   #6
only in a jeep cj
If his motor runs good, no smoke or knocks, jump all over it for 150. Sell the trans with bellhousing for 50 (you'll be doing good if you get that) and sell your old engine as a rebuildable core for 50. In the end you'll have a good motor for 50 bucks! score! It will swap right out with yours bolt for bolt. IF your clutch is smooth and works good, use your flywheel back. IF not, try his.
Use your block mounts and yes, get a new pilot bushing. The combo looks like its from a what....89 YJ?
Ed
1975 CJ-6 304 T15 Dana20 30/44 3.73
1983 CJ-8 258 T5 300 30/44 3.31 Looking for full or half hardtop buy or trade
1986 CJ-7 Laredo 4.6 stroker T5 300 30/44 3.31
1986 TJ-7 Trail Jeep project in the works
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline   Reply With Quote
Unread 06-27-2014, 10:19 PM   #7
Mean Max
Don't poke the bear
Mean Max's Avatar
Could be an '87-'89 (1/2 year in '89) YJ, I would think.
Max
Unread 06-27-2014, 10:27 PM   #8
ceej7
didnt ask what year combo was from but 88-89 is what i thought. everything in pic for 150, trans, bellhousing ,and engine.they probably left trans mated to engine so they didnt have to haul off tranny. pretty pumped about engine, should be good for another 100k!
Unread 06-28-2014, 01:20 PM   #9
carnuck
1984 J-Series Truck
ALL AMC 6 cyls 1972 and newer will bolt up (232, 4.0, 4.2. Mexican 262 and 282) Before that they were smaller bell pattern with the starter on the left (Postal Jeeps had them a bit longer than that)
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
http://tinyurl.com/jimsclads
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline   Reply With Quote
Unread 06-28-2014, 10:01 PM   #10
ceej7
ok, more questiones. what year was the last 258 made, and what, if any, were the change in horsepower numbers from my '85 to the last year manufactured?
Unread 06-28-2014, 10:13 PM   #11
only in a jeep cj
1990 was the last year used in the YJ. Same Carber BBD carb, emissions, stepper motor, and pulse air system as used in the later CJs...84 on I think.
Maybe the V belt vs serp belt was a difference but it should be basically the same motor and numbers as your 85.
Ed
Unread 06-29-2014, 04:22 AM   #12
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
The motor will bolt right up. You will need a new pilot bushing or use your old one if any good still. I bolted in a 93 4.0 into mine and put all the 258 'stuff' on it and was good to go even.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is online now   Reply With Quote
