engine swap question from a rookie. - JeepForum.com
post #1 of 4 Old 02-21-2013, 11:26 PM Thread Starter
norcallogger
1974 CJ5
My first of what im sure will be many posts as I begin my adventure of building my cj5 project.. but I think its an easy one will a 258 out if a 1987 cj 7 bolt up in a 1974 cj 5 with a 258 in it? Are the motor mounts the same? If they both have manual transmission? And is there any computer gadgets required for the 87 motor? Any help will be appricated and thanks in advance.
norcallogger is offline
post #2 of 4 Old 02-26-2013, 05:56 PM
foggybottombob
you will get more attention on this question in the CJ forum.
foggybottombob is offline
post #3 of 4 Old 02-26-2013, 06:41 PM
VooDoo2
1978 CJ7
Yes it will bolt up with no issues.
VooDoo2 is offline
post #4 of 4 Old 02-26-2013, 11:56 PM
Jeepkid1995
1979 CJ7
I agree, it will bolt up no problem. I would, however, double check that the engine you are purchasing is a CJ 258, seeing as there is no such thing as an 87 CJ. Last one was in 86. If it is an 86 engine, there will be a ECM tucked under the dash you will have to deal with, shouldn't be too much of a problem, though. Just swap it and all the wiring over to the good CJ.
->'79 CJ7 (VIN Says it's a 5, wheelbase says otherwise), 6 inches of spring lift, awaiting an MC2100 on a teamrushed MSD'd 258
-->350 time. '95 block SBC, stroked to 383, dremeled heads and big 'ol intake, maybe a Holley 750 CFM, not sure yet
--->"Safety? Buy a Volvo. Never buy a CJ, or a Chrysler Jeep knock off, for safety, fuel mileage, reliability, handling, ride, comfort, aerodynamics, quietness, convience, stability, low maintenance cost, performance, or ease of use. The only reason to buy a CJ is because you are absolutely, incurably nuts." -OldTexas
Jeepkid1995 is offline
