Engine swap question - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Engine swap question
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line~Artec JK 1 TON SWAP~Advance Adapters SYE Kits
Unread 10-20-2014, 05:43 PM   #1
Lego-26
1979 CJ7
So the bad news is my 258 shredded the #3 piston and bent the crank at the same time. After tearing apart the engine and checking things out Its not worth rebuilding.
The good news is I can pick up an older running 318 engine. The question is this, how hard is this swap? can it be done? I know I will need a conversion bell housing and a little bit of parts matching but after that? Any help would be great.
Lego-26 is offline   Reply With Quote Quick reply to this message
Unread 10-20-2014, 06:25 PM   #2
firegod33
1977 CJ5
That swap would be a total custom fab job. Not saying it wouldn't be worth it but it won't be easy. There are reasons the Ford 5.0 and Chevy 350 are the most common. Any swap can be performed with enough work and money.
Earth first... We'll Jeep the other planets later.
firegod33 is offline   Reply With Quote Quick reply to this message
Unread 10-20-2014, 07:14 PM   #3
82JeepCJ7
1982 CJ7
An AMC V8 will bolt in with very few mods. AMC inline 6s and V8s share the same bellhousing bolt pattern. The passenger side motor mount on the frame is a bit different, but overall its a bolt in swap.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline   Reply With Quote Quick reply to this message
Unread 10-20-2014, 07:23 PM   #4
LumpyGrits
Stick with AMC, unless you have time and deep-pockets.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 07:52 AM   #5
CJ7nvrstk
What they said, AMC. Super easy to do with off the shelf parts.
RED Friday. Remember Everyone Deployed
CJ7nvrstk is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 10:38 AM   #6
TIPPEDITOVER
TIPPEDITOVER's Avatar
1978 CJ5
Having done the SBC swap myself, I must agree with what the others said about cost and time. If you want to keep cost down and do minimum fab work stick with AMC.
There are companies that sell TBI fuel injection for the AMC engines, but there again the cost issue comes up.
However, that being said, there's nothing like electronic fuel injection when you are at 7,000 ft elevation and climbing a ridiculous steep trail or off camber so far you're praying it doesn't tip. Last thing you need is the engine to quit in that moment because it flooded or starved for fuel.
I'm an advocate for fuel injection, if you couldn't tell. No matter what happens, don't get discouraged and get that Jeep back on the road.
TIPPEDITOVER is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 09:43 PM   #7
82JeepCJ7
1982 CJ7
Q-jet.. Just as good as EFI at 1/10th the cost.
Unread Yesterday, 09:57 PM   #8
dg6772
I disagree, the fuel injection is way better. Not that a Q-jet is bad,I've had plenty but I am much happier with the tbi. Once understood,and using the obd1 system; you can put it on just about anything out there. I will be helping a friend put a system on a 304. All salvage parts. Keeps cost way down......
Btw computer,wiring and sensors....25 bucks total.....
Dave in Muskegon using Jeep Forum App
dg6772 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 10:14 PM   #9
TIPPEDITOVER
1978 CJ5
I've heard from a lot of different folks that the Q-Jet is a great carb and works great offroad with the angles without flooding or starving. I don't disagree. I don't have personal experience with it.
I do have extensive experience with my factory OEM TBI system and I can say is it's the last thing I think or worry about on my Jeep. I don't worry about keeping my air/fuel in tune. I don't have to. It does it on it's own no matter the temp or barometric conditions.
Hijack mode: OFF
