Engine swap - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Engine swap
ANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete The Jeep Forum Discount is ON!The Original 3/8" Ruffstuff Diff Cover!
Unread 07-27-2015, 06:49 PM   #1
Jeepswat
1955 CJ5
Engine swap
1955 cj5. Would like some solid advice how to swap my 4 cyl to a strait 6 out of a 1996 xj. Want to keep the stock 3 speed that's in it. Has overdrive added to trans. Hope there is a bellhousing adapter out there someone knows of. Thanks
Jeepswat is offline   Reply With Quote Quick reply to this message
Unread 07-28-2015, 02:47 AM   #2
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I don't think the 4.0L inline 6 is going to fit in your '55 without some major modifications.
AMC lengthened the front clip of CJs in the early 70's to accommodate the longer I6 engine.
I think a V6 would be a better choice for you.
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread 07-28-2015, 04:54 AM   #3
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Sorry, like Matt says, it is too long to fit. Jeep used a Buick V6 in some, but. I am not sure what they had to do to make that fit as far as body mods go.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 07-28-2015, 09:29 AM   #4
CSP
OP, your overdrive would be attached to the transfer case, not the transmission.
The later, even fire Buick V6s are a good swap option as is the Chevy 4.3. Neither require body modifications.
CSP is offline   Reply With Quote Quick reply to this message
Unread 07-28-2015, 03:33 PM   #5
jeepdaddy2000
1971 CJ5
You also have the option of a modern 4 cylinder.
Either the V6 or modern 4 will be an upgrade in power from the existing F head. Rear wheel drive Buick V6 engines are getting hard to find. The better choice would probably be a V6 Vortec.
Adapters for standard Ford and Chevy engines are available. Remember, a swap will require more than a simple bolt in, however, a 4 or V6 would minimize the effort.
Also be aware, the stock steering and brakes are marginal at best. Getting your rig up to 65-70 MPH with the new motor may very well push your existing systems outside their safety envelope.
jeepdaddy2000 is offline   Reply With Quote Quick reply to this message
Unread 07-30-2015, 11:48 AM   #6
raven3
1973 CJ5
Would second the V6 Vortex.
Hot Rod magazine has a good write up on carbureting the Vortex
using an Edelbrock 4 bbl carburetor intake manifold.
Vortex V8 may also fit in short nose body configuration.
raven3 is offline   Reply With Quote Quick reply to this message
Unread 07-30-2015, 01:20 PM   #7
firegod33
1977 CJ5
Buick 231, 225, or 4.3 V6 is going to be the best bet. An inline will never fit in the engine bay. Personally, I'd go with the 4.3 and keep the efi.
Earth first... We'll Jeep the other planets later.
firegod33 is offline   Reply With Quote Quick reply to this message
Unread 07-30-2015, 01:21 PM   #8
I6CJ7
LS 4.8 V8, have fun and be done with it.. Lol
I6CJ7 is offline   Reply With Quote Quick reply to this message
Unread 07-30-2015, 02:32 PM   #9
Jeepswat
1955 CJ5
Thanks everybody. the jeep gods have schooled me!
