Engine Swap - JeepForum.com
post #1 of 5 Old 01-29-2013, 06:28 PM Thread Starter
bear991
1978 CJ7
Engine Swap
Need some info....I want to put a late model GM engine in my jeep...not a computer engine but a fuel injected late model engine. I have a 78 CJ7 with the th400 tranny and quadra trac system and currently a very tired 304. What adapters would I need and where would I find them. This is a great site and have been visiting for some time and am now a member. thanks ahead for any info you can give
bear991 is offline
post #2 of 5 Old 01-29-2013, 06:33 PM
Jbwardfamily
1978 CJ5
Search Novak Adapters. Best place I know of. Lots of good info too.
Jbwardfamily is offline
post #3 of 5 Old 01-29-2013, 06:36 PM Thread Starter
bear991
1978 CJ7
Thanks for info
bear991 is offline
post #4 of 5 Old 01-29-2013, 06:58 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Check out Ron Francis Wireworks for "stand-alone" engine wiring harnesses that allow late model fuel injected engine installations into any vehicle.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #5 of 5 Old 01-29-2013, 07:07 PM
timgr
1975 CJ6
When you say GM do you mean Chevy? If you want to convert to a Chevy, you need to put the Quadratrac output shaft into a Chevy TH400 transmission case. The TH400 behind your 304 has an AMC case. Unfortunately, the output shaft is the very last thing to come out of the case when you take the transmission apart, so you'll need to completely tear down the TH400 to swap to a Chevy transmission case.
1) '77 J10 LWB, 258/T15/D20/3.54 bone stock, low options (delete radio), PS, hubcaps. 2) '82 J20 360/T18/NP208/3.73, KOs, 7600 GVWR 3) '75 CJ-6, 304/T15, PS, BFG KM2s, soft top 4) '95 VW Golf Sport 2000cc 2D
timgr is offline
