Engine Swap ? - JeepForum.com
post #1 of 5 Old 09-07-2011, 11:17 AM Thread Starter
hagan39
1981 CJ7
Engine Swap ?
Okay... saw this in Columbus http://www.jeepforum.com/forum/f126/...rokee-1262234/
and wanted to see if this would work or not... currently have a CJ7 and was thinking instead of buying a Howell EFI kit this might be an alternative. That way I could try and sell the old engine and carb to save on cost as well.
What all would I be looking for on this if possible... I currently am running a 4.0 manual.
hagan39 is offline
post #2 of 5 Old 09-07-2011, 12:15 PM Thread Starter
hagan39
1981 CJ7
bump
hagan39 is offline
post #3 of 5 Old 09-08-2011, 06:39 PM Thread Starter
hagan39
1981 CJ7
Anyone?
hagan39 is offline
post #4 of 5 Old 09-08-2011, 06:51 PM
mopar346
Here are a few thought, you may not get much for yours. The ad doesn't state the condition of the engine and for the most part people don't have dealers pull out good engine. I believe it will work but I am not sure. I do know that many times in a swap like that you end up finding other things when you plug and play like bad sensors and such. The ad also doesn't mention fuel pump, which is electric and would be required for the EFI engine. Add up everything you think you will need add $500 and double it and you probably wont be too far off when finished.
Careful your character's showing
mopar346 is offline
post #5 of 5 Old 09-08-2011, 06:58 PM Thread Starter
hagan39
1981 CJ7
Looks like your about spot on Mopar... nice little write up I just found and seems price as a little more then I accounted for, http://www.4x4wire.com/jeep/tech/engine/fi40swap01/
hagan39 is offline
Engine Swap rchimileski Jeep CJ Forum 3 08-10-2011 07:27 AM
Engine Swap rchimileski Jeep CJ Forum 0 08-10-2011 02:34 AM
engine swap for a 75 cj5 75-cj5 Jeep CJ Forum 13 11-01-2009 09:55 AM
Engine swap or engine and transmission swap Notplayn Jeep CJ Forum 3 07-13-2008 07:31 PM
Tranny swap now with future engine swap in mind gestuhlm Jeep CJ Forum 1 04-23-2006 07:49 PM
