Engine starts, then immediately dies..HELP! - JeepForum.com
post #1 of 11 Old 04-28-2010, 11:07 PM Thread Starter
tim843
1978 CJ5
Just bought a 78 CJ5 304 V8 3speed and has started and driven fine for 2 weeks. Right after reinstalling the speedo cluster (not easy and couldnt avoid disturbing alot of wiring sliding it in) and testing gauges, dash wiring and fuse box with a light tester and meter, the engine turns over and starts, but immediately dies. It's always started no problem before. When I pulled out the aftermarket Sunpro fuel gauge mounted under the dash, it touched the dash and sparked. Checked fusebox and replaced cluster feed fuse and panel lights fuse. Also replaced the coil with a new one. Still won't stay running. What could I have disturbed or blown up that would cause this?
Thanks,
Tim
tim843 is offline
post #2 of 11 Old 04-29-2010, 08:26 AM
jeepsarecool
jeepsarecool's Avatar
1982 CJ7
Sounds more like a clogged fuel filter or something like that. May just be coincidence that it happened when you pulled the cluster.
Check out my
CJ7 - God's gift to the masochist.
jeepsarecool is offline
post #3 of 11 Old 04-29-2010, 10:10 AM
nshefbuch
1982 CJ7
its ignition module. on older jeeps it would be the ballast resistor. went through the same thing on my old cj5 and mine was a $5 ballast resistor. now i carry spares just incase.
nshefbuch is offline
post #4 of 11 Old 04-29-2010, 10:14 AM
Andy5150
I had a 76' dodge aspen that did that. You could here the engine running while you were holding the key turned, but when you released the key to the run position, the motor died instantly. It was a bad ballast resisitor.
Andy5150 is offline
post #5 of 11 Old 04-29-2010, 05:28 PM
neals80
1980 CJ7
My bet Fuel.....loosen your fuel fill, vent filters...run it off a gas can...
Neal Trombley
1980 CJ 7
SW FLORIDA
IF I WANTED A HUMMER I WOULD HAVE CALLED YOUR GIRLFRIEND!!
neals80 is offline
post #6 of 11 Old 04-29-2010, 07:22 PM
JeepHammer
Running On Empty...
1973 CJ5
Factory Tach?
If you have a factory tach, you can't remove the gauge cluster without unplugging it,
And the vehicle won't run with key switch in the 'Run' position without the Tach hooked up.
The gauges are all powered up by the same circuit that powers the ignition.
If you blew the Ign. fuse when you grounded the power to the fuel gauge,
Then I'd check that fuse.
If you think it's the ignition under the hood,
Then pull the coil connector off,
Ground your test light to the battery negative,
And probe the coil connector 'RED' wire.
YOU MUST REMOVE IT FROM THE COIL TO GET A GOOD READING.
With the key switch in the 'Run' position, you should get a 'Dim' light.
This will tell you if the ignition switch, fuse, ignition resistor...
All the stuff leading to the actual ignition is working.
With the key switch in the 'Start' or 'Cranking' position,
You should get a 'BRIGHT' light.
This will tell you if you are getting the power 'Jumper' from the starter relay ('Solenoid') to the ignition.
My guess is you WILL NOT get power to the coil CONNECTOR RED WIRE,
And that will tell you right away there is a glitch in the dash wiring,
Fuse, something unplugged, something grounded that shouldn't be, ect.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #7 of 11 Old 05-01-2010, 02:00 PM Thread Starter
tim843
1978 CJ5
Test Results
Let me give you some test results.
With multimeter on coil positive(+) and good ground:
Key off: 0
Start 9.0v
Run 1.0v
I tried this test from the chiltons AMC 72-85 book. I tested coil to distributer cap wire pulling it off at the dist cap, placing it 1/2 " away from a good ground, result, got spark when trying to start ign.
What does this tell you guys?
I live in Louisville, KY and am so anxious to get this solved, I'm working on it on Derby Day when I could be at Churchill Downs right now! Going back out to check some thing recently posted here. Be back,
Thanks,
Tim
tim843 is offline
post #8 of 11 Old 05-01-2010, 02:18 PM
Cuder
X2, But I would look at the float sticking closed on the carb.
Cuder is offline
post #9 of 11 Old 05-07-2010, 07:07 AM Thread Starter
tim843
1978 CJ5
First thanks to all who pitched in to help. Found the problem(s). The aftermarket fuel gauge I mentioned that sparked when I pulled it out seemed to cause the low volts in run position. It was mounted on a steel plate and screwed in to the radio opening. I screwed it back in (which grounded itself to the dash) and thats when it starts then dies at 1volt in run. I've since taken it all the way out (after I disconnected the battery this time!) capped off those wires. I've also pulled open the dash and found 3 wires melted together! Pink 16, green 18 and red/white. All 3 go from the connector under the dash that the steering column wires connect to, up and over the steer column, either out the fire wall or in the fuse box. Ive cut out the bad sections of ea. wire and getting ready to splice in new wire. Any tips?
Thanks again for everyone's help,
Tim
tim843 is offline
post #10 of 11 Old 05-07-2010, 09:42 AM
JeepHammer
Running On Empty...
1973 CJ5
If you were taking voltage readings,
Then you didn't do what I told you to do.
Take the coil connector off the coil,
Test the wires with a TEST LIGHT as described above.
Probably one of two things,
You have the 'Ignition RUN' circuit grounded out with the new wiring,
(Jeep starts on a 'Cranking' or 'Start' circuit, but when you drop the key switch back to the 'Run' position, you probably aren't getting power to coil/module)
OR,
You have a bad 'Run' circuit in the module from leaving the key in the 'Run' position while you were doing wiring.
Do the tests I laid out and you will QUICKLY find the issue.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
post #11 of 11 Old 05-25-2010, 07:23 AM Thread Starter
tim843
1978 CJ5
Just wanted to follow up: Finally took it too a professional. An ignition wire in the steering column had rubbed open and was shorting. Also the blue wire wasnt making a good contact on the starter solenoid post.
Thank you all for helping this Jeep newbie.
If you live in the Louisville, KY area, I highly recommend Jeffersontown Auto Electric 502-267-8558
tim843 is offline
cj5 , electrical , engine , fuse , wiring
258 Finally Starts, Then Dies Skinnyfeet Jeep CJ Forum 13 10-05-2010 07:28 PM
Engine starts but does not keep running grizzlyjeepcj Jeep CJ Forum 12 09-27-2009 11:45 AM
Engine Dies.... elks96 Jeep CJ Forum 11 05-06-2009 11:13 AM
Engine skips and dies but starts right back! Born2Ride Jeep CJ Forum 11 12-23-2008 04:23 PM
1975 4.2L starts and dies immediately Jeepin_XJ_101 Jeep CJ Forum 11 07-06-2008 03:32 PM
