Engine start - Page 2 - JeepForum.com
post #16 of 26 Old 06-11-2013, 05:49 PM Thread Starter
LeePrather
1978 CJ5
It is. I installed a painless harness
LeePrather is offline
post #17 of 26 Old 06-11-2013, 05:53 PM
LumpyGrits
OK-"painless" that'll explain much.. I have found'e to be more 'pain-n-arse'.....LOL
Is it a tube or GM blade type?
LG
LumpyGrits is offline
post #18 of 26 Old 06-11-2013, 06:00 PM Thread Starter
LeePrather
1978 CJ5
Gm type and that fixed the issue. Lol I have been sweating this thing for a few days now...I just happened to think last ditch
post #19 of 26 Old 06-11-2013, 06:42 PM
LumpyGrits
Keep an eye on it.......That fuse blew for a REASON.
Is it run'n now?
LG
post #20 of 26 Old 06-11-2013, 07:26 PM Thread Starter
LeePrather
1978 CJ5
It is running like a champ and I definitely agree it blew for a reason. Now it's time to work on the engine temp running hot and oil pressure gauge melting (3 times now). I like the painless harness so far
post #21 of 26 Old 06-11-2013, 07:42 PM
LumpyGrits
Run'n hot--Do a 'rod-out' on that radiator. Your just chase'n your tail till you do that.
Also make sure your ign timing is correct and your not run'n 'lean' in your carb. Pull the s'plugs and read the tip color.
Oil pressure gauge melts, WTH?? Is it mech or ele?
LG
post #22 of 26 Old 06-11-2013, 07:58 PM Thread Starter
LeePrather
1978 CJ5
Electrical, but that's changing tomorrow...already picked out a 3 gauge mechanical Sunpro set I'm going to buy.
post #23 of 26 Old 06-11-2013, 08:23 PM
LumpyGrits
You have a high amp current flow issue if your melt'n ele oil pressure gauges.
Find out the why........before you have an ele. fire.
LG
post #24 of 26 Old 06-12-2013, 12:09 AM
rah2eq
1978 CJ5
I also had a couple of oil pressure gauges melt on me. I used the electrical ones that look stock. The +12V hot wire will melt it if you connect it to the terminal near the plus sign on the gauge. Turns out that is for the voltmeter gauge that uses the same backing. I switched the wiring to the correct way on a new gauge and mine has been fine.
1978 CJ5 - 304 V8 - Twin Sticked and sitting on 35's
2010 JK- Rock Krawler 2.5" on 35" KM2's
rah2eq is offline
post #25 of 26 Old 06-12-2013, 05:22 AM Thread Starter
LeePrather
1978 CJ5
I'm pretty sure that's what's happening to me too so I'm just gonna go mechanical instead
post #26 of 26 Old 06-12-2013, 07:57 PM Thread Starter
LeePrather
1978 CJ5
An update, mechanical gauges are the best! (And it seems my sending unit wire was trapped under the solenoid and rubbed to bare wire). Lol...
