Engine start - JeepForum.com
post #1 of 26 Old 06-11-2013, 10:24 AM Thread Starter
LeePrather
1978 CJ5
Engine start
I've had the battery dead for about 5 days and I've been working on different things under it. Had to replace the battery because it wouldn't turn over or take a jump. Installed an inline battery cutoff thinking that something is draining on the battery. New battery, engine cranks and fires once but will not start. I put some starter fluid in, same thing. Last night the carb puffed white smoke. Any ideas? I haven't touched any of the starting pieces?
LeePrather is offline
post #2 of 26 Old 06-11-2013, 11:40 AM Thread Starter
LeePrather
1978 CJ5
The fan belt was not wide enough and was screeching. Is it possible that turning the engine over somehow caused a timing issue?
post #3 of 26 Old 06-11-2013, 01:13 PM
LumpyGrits
Run a wire from the POS(+)side of your battery to the POS(+)side of your coil.
Try start'n it. IF it's starts now, you have a bad IGN. switch i'll bet
As per the battery drain. I bet it's via your alt.
Disconnect the alt, and reconnect the battery and let it sit for a few days. AFTER you fully recharge the battery.
NEVER let a dead/flat battery sit as batteries have a memory.......
LG
LumpyGrits is offline
post #4 of 26 Old 06-11-2013, 02:03 PM Thread Starter
LeePrather
1978 CJ5
I ran positive battery to positive coil an all it did was turn over and never sounded like it had fuel. Without that jumper it tries to crank with fuel...you can hear ignition trying to take place?
post #5 of 26 Old 06-11-2013, 02:11 PM
LumpyGrits
Sounds like you MAY have lost the pick-up coil inside the dizzy.
LG
post #6 of 26 Old 06-11-2013, 04:20 PM Thread Starter
LeePrather
1978 CJ5
Just an update, I did some research on the pickup coil an it seems it can be tested pretty easily by a continuity test. I tested and it is reading voltage. Is timing a possibility?
post #7 of 26 Old 06-11-2013, 04:24 PM
hotrod351
1955 M-38
check the timing, hook up a timing light and crank it and watch where the timing marks line up. i had to start a engine that way once because it was so far off. or put your finger in number and tap it over until it pops out and see if your close on the crank.
hotrod351 is offline
post #8 of 26 Old 06-11-2013, 04:25 PM
LumpyGrits
Not unless you messed with timing by turn'n the dizzy or pulled the whole dizzy out.
THEN-YEAH.....
LG
post #9 of 26 Old 06-11-2013, 04:29 PM Thread Starter
LeePrather
1978 CJ5
I had issues with the fan belt and I had to replace it. Is there any chance I could have thrown the timing off? The belt wasn't turning the pulleys? I'm guessing timing is gonna be the next thing even though I really don't know what I'm doing! Lol another jeep learning experience!
post #10 of 26 Old 06-11-2013, 04:40 PM
LumpyGrits
YOU really need to get a copy of the Factory Service Manual. Read the trouble shooting sections.....
Unless you moved the dizzy it S/B OK, I would think.
What else have you done to this jeep?
LG
post #11 of 26 Old 06-11-2013, 04:50 PM
rah2eq
1978 CJ5
Keep in mind that your timing is set by the timing chain, not the belts. The belts just turn your accessories like the water pump and fan. If I were you and it starts to crank when you put starting fluid in it is make sure that you get fuel to the carb. Try taking off the air cleaner and making sure that your accelerator pump can squirt fuel in, that will be an indicator of whether or not it has fuel as long as the diaphragm for that isn't blown. If it has caught once or twice for you already I would assume that your timing is alright enough for it to at least get started.
1978 CJ5 - 304 V8 - Twin Sticked and sitting on 35's
2010 JK- Rock Krawler 2.5" on 35" KM2's
rah2eq is offline
post #12 of 26 Old 06-11-2013, 05:32 PM Thread Starter
LeePrather
1978 CJ5
Damn coil fuse is blown
post #13 of 26 Old 06-11-2013, 05:33 PM
LumpyGrits
Coil fuse??
LG
post #14 of 26 Old 06-11-2013, 05:40 PM Thread Starter
LeePrather
1978 CJ5
30amp fuse in my panel labeled as "coil"
post #15 of 26 Old 06-11-2013, 05:45 PM
CSP
It must be an aftermarket wiring harness.
As said, the belts don't have anything to do with ignition timing.
CSP is offline
