Engine stalls - JeepForum.com
post #1 of 4 Old 05-22-2010, 10:15 PM Thread Starter
75CJLevi
1975 CJ5
Engine stalls
I am having trouble with my engine stalling. I turn it over and it runs for a few seconds then it just stops. The RPMs fall to zero suddenly. Before it stalls I can see the RPMs drop suddenly and go back up. It is almost as if the fuel supply gets cut off. I thought it might be the fuel filter, but I just replaced it a few months back. I recently just put new gas in from a gas can. Could it be clogged now? Any help is very appreciated.
1975 CJ5 Levi Edition, 304 V8 AMC; Blue with denim seats.
75CJLevi is offline
post #2 of 4 Old 05-22-2010, 10:32 PM
Trapshooter
Sounds as though you may have some trash in your fuel system. I would disconnect the fuel line and run it into a bucket; have someone crank the engine for you and see if you can getting a good supply to the carb.
Be care when dealing with raw gas.
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #3 of 4 Old 05-22-2010, 10:42 PM Thread Starter
75CJLevi
1975 CJ5
Thanks
I will try that. I figured it had to be something with the fuel line.
75CJLevi is offline
post #4 of 4 Old 05-23-2010, 05:28 AM
seejayseven
floats stuck ? give a few taps on each side of the float bowl ,then try again
seejayseven is offline
Engine stalls, DUI ignition , Metering pins don't move. ineedabrew Jeep CJ Forum 4 08-22-2009 10:28 AM
258 stalls when w/o AC on thundermunkey Jeep CJ Forum 3 01-06-2009 11:47 AM
Engine spudders and stalls when headlight are on jeepin cj-5 Jeep CJ Forum 3 06-21-2008 09:55 PM
engine stalls at idle willem Jeep CJ Forum 0 09-24-2007 11:42 PM
engine stalls!?? mherois Jeep CJ Forum 4 08-22-2007 06:59 PM
