engine sputters when shut off - JeepForum.com
post #1 of 4 Old 07-22-2007, 03:53 PM Thread Starter
Jason Cramer
What can I do to stop my engine from sputtering when I turn the key off?
CJ7 AMC 4.2 inline 6
Jason Cramer is offline
post #2 of 4 Old 07-22-2007, 04:52 PM
Bard
Sounds like time for a tune up. Try plugs and wires and cleaning the carb out. If that doesn't work, I would reset your timing which should fix it.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #3 of 4 Old 07-23-2007, 06:37 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Also adjust your idle speed to lower than 900 RPM. If you can't do it then as Bard sugested you need a tuneup.
I couldn't get my jeep to idle lower than 950 RPM until I improved the ignition system with a TFI upgrade. Then I can lower the RPM to 550 RPM but generally I leave it between 650-750 RPM.
John Strenk is offline
post #4 of 4 Old 07-23-2007, 11:52 AM
Heepajeep
Decarb it with Seafoam.
You might have carbon deposits built up in the combustion chamber.
Causing hotspots that continue to glow and thus ignite latent fuel after ignition is turned off.
Also known as dieseling.
Heepajeep is offline
73 CJ5 ignition won't shut off engine !! Lilnuts Jeep CJ Forum 14 10-10-2013 11:18 PM
Engine Wont Shut Off glsimmons1 Jeep CJ Forum 2 10-19-2009 01:15 PM
Engine Spits & Sputters When Driving Slow 79BlackPearl Jeep CJ Forum 4 10-08-2009 10:05 PM
Engine sputters at half a tank BrockGrimes Jeep CJ Forum 14 09-23-2009 06:23 PM
engine sputters when i put on brakes YoungGunz Jeep CJ Forum 14 08-29-2004 08:51 PM
