Engine sputters at half a tank - JeepForum.com
post #1 of 15 Old 09-21-2009, 11:42 AM Thread Starter
BrockGrimes
I'm pretty sure my gas gauge is working properly.
I'll be driving and the jeep will start to surge, spit, and sputter.
If i pump the gas i can kinda keep it going to a max of about 35mph or half throttle, but then eventually it'll shut off.
If it shuts off, it'll be hard to start for a couple min. then it starts and drives fine.
This happens around half a tank.
I was figuring crap in the gas but I run 2 fuel filters, 1 before fuel pump and 1 before carb, and it runs fine after I get it restarted.
WTFO?
USN Jeep Club Hull #1
BrockGrimes is offline
post #2 of 15 Old 09-21-2009, 12:11 PM
OlivergreenCJ7
I wonder if it could be a float problem. Would make it easier knowing the engine, carb , etc.
OlivergreenCJ7 is offline
post #3 of 15 Old 09-21-2009, 01:31 PM Thread Starter
BrockGrimes
258, carter carb, don't see it being a float as it runs fine as long as it's above half a tank.
Was thinking a pickup but it runs fine after it restarts.
post #4 of 15 Old 09-21-2009, 03:26 PM
kercher
kercher's Avatar
how old are the fuel line hoses?
is there any gas in the fuel filter when it shuts off?
kercher is offline
post #5 of 15 Old 09-21-2009, 05:45 PM
zillla
1930 VJ
Maybe a hole in the fuel draw line in the tank. That's my guess.. When the fuel level reaches the hole the fuel pump can't pump enough cause it's coming out the hole and going back into the tank..
zillla is offline
post #6 of 15 Old 09-21-2009, 05:53 PM
gmakra
Check your evaporate emissions canister filter on the bottom it maybe plugged.
gmakra is offline
post #7 of 15 Old 09-21-2009, 10:54 PM
CJfreak
1975 CJ5
X2 on what zillla said
'75 CJ5 w/304/T150/D20/D44's/3.07/33" Thornbirds/Glass Body...
CJfreak is offline
post #8 of 15 Old 09-21-2009, 10:59 PM
carnuck
1984 J-Series Truck
Make sure there isn't major vacuum when you loosen the cap next time it happens. If not, then it's not the tank holding the suction back. The "sock" in the tank collapses from being softened up by the MTBE and alcohol in fuel. Kind of like a sock stuck in the end of a vacuum. Nothing gets past it till you pull it out. I removed mine and left the one before the fuel pump.
carnuck is offline
post #9 of 15 Old 09-22-2009, 12:19 AM
h2ojeep
1978 CJ7
I had the same problem. the advise listed before, (hole in the line, vacuum, and canister filter) are all good ideas to check. I would add looking at the fuel filter just before the carb and make sure the return line is above the supply line (12 oclock) on the carburetor side of the filter and also pressure check your fuel pump (even if it is a new pump).
And check to make sure you dont have a small hole or loose conection in the line from the tank to the fuel pump (thus pulling air).(you will probably have to find some way to pressure the line someway to check that)
Recently someone ran a thread, and had connected a vacuum line to the return line on the filter (pulling a vaccum on the tank).... just fishing, but check to make sure
I would also ask to another symptom: does it act like a vapor lock? and work better when cooled down some? Does the problem go away when you fill the tank?
h2ojeep is offline
post #10 of 15 Old 09-22-2009, 12:21 PM Thread Starter
BrockGrimes
Like stated above runs perfect, idles great, till about half a tank, then it'll surge, sputters then cut off, I pump the gas and turn it over a couple times it starts then runs just fine till I get home or to teh gas station, I refill then drive it till the next time.
With the ability to drive it before and after it happens I'm not inclined to believe it's a fuel supply issue unless trash in the tank is causing it, but settles out of the way once it's shut off for a min or so. I have seen this happen on having to big a rubber line up near the pump or carb. Maybe the ignition module is getting to warm?
The rubber near the mech. pump and carb are newer, and the fuel filters also, the one at the carb is turned the right way and the lines are connected properly.
post #11 of 15 Old 09-22-2009, 01:06 PM
LSUtiger
1980 CJ5
Maybe try to run it without that extra fuel filter before the pump?
1980 cj5 401, t-176, p/s., YJ p/b, tfi/hei hybrid, 3.73 30/44
LSUtiger is offline
post #12 of 15 Old 09-22-2009, 02:20 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Originally Posted by carnuck View Post
Make sure there isn't major vacuum when you loosen the cap next time it happens. .....
This almost sounds like you're not letting air into the tank becuase of a plugged vent. You just can't keep on sucking out gas without replacing it with air in the tank.
Try driving around with a loose gas cap. Just don't loose it though.
John Strenk is offline
post #13 of 15 Old 09-22-2009, 05:09 PM Thread Starter
BrockGrimes
Wouldn't it stay vacuumed? After it shuts down I crank it a couple times and it starts.
post #14 of 15 Old 09-22-2009, 07:46 PM
John Strenk
1976 CJ5
Depends upon how well it's sealed. A perfect seal would stay vacuumed but nothing is perfect on a CJ. Your Gas cap could have a dry o-ring on it or some small seal will leak but not fast enough compaired when your driving.
Could also be a fuel hose that is collapsing when the engine is sucking gas harder. As soon as you stop, it gives a second for the hose to pop out again.
Then again it could be the first fuel filter plugging up also.
post #15 of 15 Old 09-23-2009, 07:23 PM Thread Starter
BrockGrimes
I added the first filter because I thought maybe it had trash getting through the filter by the carb.
I figured a vaccum issue would appear long before half a tank.
It's weird.
New gas tank sending unit and now it reads half CJ7_Jim Jeep CJ Forum 6 11-14-2009 10:09 PM
Engine Spits & Sputters When Driving Slow 79BlackPearl Jeep CJ Forum 4 10-08-2009 11:05 PM
Tank is full, fuel gauge reads Half tank!?! martyweir Jeep CJ Forum 10 09-25-2008 07:55 AM
engine sputters when shut off Jason Cramer Jeep CJ Forum 3 07-23-2007 12:52 PM
engine sputters when i put on brakes YoungGunz Jeep CJ Forum 14 08-29-2004 09:51 PM
