Engine Runs Backwards After Turning Off... - JeepForum.com
post #1 of 16 Old 09-16-2009, 07:50 AM Thread Starter
poppatello
I can't remember what it's called, but when I turn my key off the motor runs backwards. I know this is bad. It has pretty much always done it since I've had it. (two years) I have done many upgrades since I bought it. Carb, nutter, plugs, wires. I never really bothered with it since it was just a turn or two. Now last night it was quite fast and for about five seconds or so... This got me really concern. I don't want to damage the valves or rods. The motor is a 150 with only 34,000 on it. Any ideas what I can do to stop this? The timing seems to be right on where it should be so what else could be the cause?
In a world full of copy cats, be an original...
Paved Roads
A Fine Example of Needless Government Spending
Originally Posted by berserker View Post
Sometimes it a good idea to pull a vacuum hose before the wife rides in it--you can tell her you need a new ____ and once you get your new ____ you can reconnect the hose. :)
84 Cj 7 w/ 4-Banger, 4.5" BDS lift, 1/2 Trans Drop, Twin Stick, 32" Tire, Front Aussie Locker, No Sound System Yet, No Armor, Warn 8274 Not Installed, Webber Carb Upgrade, Luckycheese Ing. Upgrade...
poppatello is offline
post #2 of 16 Old 09-16-2009, 09:11 AM
KMD
1976 CJ7
running lean or too hot. Is the egr still hooked up and working? The egr helps keep cylinders cool. Also try running some seafoam through it to clean any carbon off the pistons.
KMD is offline
post #3 of 16 Old 09-16-2009, 09:14 AM
JimNut
Its usually referred to as dieseling. I think R08ert pretty much nailed it. You can also try and retard your timing a few degree's and see if that helps any.
Build it, Wheel it, Break it, Fix it and Repeat!
JimNut is offline
post #4 of 16 Old 09-16-2009, 09:41 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Also make sure your throttle is closed far enough at idle. You should be ideling around 600-800 RPM or you will get dieseling. Having the idle set to high allows a rich mixture to enter the engine and if there is any carbon build up. It will fire off the mixture without a spark.
John Strenk is online now
post #5 of 16 Old 09-16-2009, 02:13 PM Thread Starter
poppatello
Ok, I do not have the EGR hooked up. As far as the idle adjustment, I think that is ok. It did the same thing with the carter carb so I am thinking it's not that. It may have carbon bill up as the thing sat almost 10 years before I got it. Even if it has only 34,000 on it, old oil can cause carbon piles too. Now will the seafoam clog my oil filter? I just did an oil change on it. I did notice one thing though. If I pull up somewhere and turn the key right off it diesels worst. If I let it idle a few seconds, it isn't as bad...
Paved Roads
post #6 of 16 Old 09-16-2009, 03:20 PM
CSP
Sounds like you may have the timing set too far advanced and possibly a lean fuel mixture creating hot spots in the cylinders. Letting it idle allows the cylinders to cool down.
Carbon buildup doesn't come from non-use. We're talking about carbon deposits in the combustion chamber as a result of bad fuel mixture, cheap gas, the wrong spark plug heat index, etc.
What is your idle speed? Saying you "think" it's ok really doesn't mean anything.
CSP is offline
post #7 of 16 Old 09-16-2009, 03:26 PM
leavundst
Junior Member
Mine does the same thing and a friend is telling me it's a timing issue. Mine will also occasionally shut down fine. But 90% of the time it does not.
leavundst is offline
post #8 of 16 Old 09-16-2009, 03:47 PM
dzride
Most of the time it's because of timing. Just turn distributor 5-10 min clockwise. I hope it helps.
dzride is offline
post #9 of 16 Old 09-16-2009, 10:13 PM
79cj7stone
1979 CJ7
it timing! my motor was doing it after a rebuild and we adjusted the timing and it hasnt done it since so go with the timing!
79cj7stone is offline
post #10 of 16 Old 09-17-2009, 07:31 AM
dfuss
1979 CJ7
I adjusted my timing to 8 last week from 6 (Nutter done by PO, trying to tune it up to what's recommended by the forum) and it immediately started doing as you describe when I turn it off. It had never done it before, so I can only assume it is the culprit.
'84 CJ7 - AMC 258, soft top, 32x11.50 Remington Wide Brutes
'79 CJ7 - AMC 360, hard top, 33x12.50 BFG KM's
dfuss is offline
post #11 of 16 Old 09-17-2009, 08:09 AM
KMD
1976 CJ7
if your timing is good and you hook the egr back up I am pretty sure your problem will be gone. You may even get to run a little more advance. Egr makes a big difference in cylinder temp.
KMD is offline
post #12 of 16 Old 09-17-2009, 03:43 PM Thread Starter
poppatello
Anyone have a break down on the vac lines for the EGR? Mine came unhooked.
Paved Roads
post #13 of 16 Old 09-17-2009, 03:45 PM Thread Starter
poppatello
When I did the bypass and checked the timing, it was right on 8 without me making and adjustments. I have been cautious to how I shut down the engine and if I let it run once I stop it doesn't do it as bad. If I pull right up to some place and shut it right off, it gets worst.
Paved Roads
post #14 of 16 Old 09-18-2009, 12:13 AM
carnuck
1984 J-Series Truck
Vacuum leak or idle too high. Did you remove the electric kickdown on the side of the carb?
carnuck is offline
post #15 of 16 Old 09-18-2009, 08:18 AM
CSP
http://home.sprynet.com/~dale02/
CSP is offline
engine running backwards vtjeeps Jeep CJ Forum 145 05-20-2011 02:42 PM
Engine still runs...still won't shut off SQF1 Jeep CJ Forum 4 04-20-2009 06:56 AM
83 cj7 engine runs but does not go in gear ca angels Jeep CJ Forum 13 05-09-2008 09:07 PM
New Engine Runs!! But I have 2 questions. jadams68 Jeep CJ Forum 13 07-08-2005 12:00 PM
Engine keeps sliding backwards only in a jeep cj Jeep CJ Forum 0 07-31-2002 06:48 PM
