Engine question - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Engine question
CCOR is your 1 stop source for everything Jeep!Stainless Steel Door Hinge PinsPoly Door Hinge Bushings
Unread 09-06-2014, 06:26 PM   #1
a_ron
Engine question
I seem to have found a 304 V8 engine for $100. My question is will it fit into my 76 CJ7 that currently holds a 232 i6? I understand in theory it will, but do I need to make modifications to make this happen?
a_ron is offline   Reply With Quote Quick reply to this message
Unread 09-06-2014, 07:46 PM   #2
PanteraPilot
1978 CJ5
I don't have all the answers here, but I suggest a "search" for "engine swap". There' a bunch written about it and I think it was basically possible but a ton of headache and expense.
PanteraPilot is offline   Reply With Quote Quick reply to this message
Unread 09-06-2014, 09:53 PM   #3
roboto65
1976 CJ5
Yes the motor mounts will have to be changed but like has been said there are many threads on this but yes it can be done pretty easy just swapping parts.
They say money can't buy happiness but it can buy Jeep parts...and Jeep parts make me really Happy.
roboto65 is offline   Reply With Quote Quick reply to this message
Unread 09-07-2014, 12:16 AM   #4
ctorj
1977 CJ7
Yes it came stock in the Cj7 and CJ6 in 76 as a option. All you need is the Engine mounts/Radiator/ ans small parts from another CJ with the 304. Everything is a Bolt up.
1977 CJ7. 3.9 Cummins 4BT, ZF5, Dana 300, SOA
ctorj is offline   Reply With Quote Quick reply to this message
Unread 09-07-2014, 07:14 AM   #5
lucdog
lucdog's Avatar
1980 CJ5
When engine mounts are mentioned, whats meant are frame mounts, and, only the frame mount on the passenger side needs changed. Motor mounts (the ones that bolt to the block) will need to be for a AMC V8 .
The I6 radiator will work, but, it's probably just a 2 core, so a 3 core will likely be needed, to keep the V8 from overheating.
Depending on what ignition (distributor) and the ignition system, both engines have, a change may be necessary.
1957 WILLYS pickup, needs work.
1973 J 4000,
1978 CJ7 DD.
1979 CJ7 360, TH400/Quadratrac trail Jeep.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7 pretty weekend and sometimes to work Driver in the summer, My first rebuild, if the Q-trac and 5 are broke, this one is the one to take. its just as capable as the other 2, except nice paint.
1984 Grand Wagoneer, 1 ton axles, great 360/727, and a big a$& tree fell on it .
1989 YJ the CJ to YJ conversion.
2005 TJ Rubicon.
2011 Grand Cherokee Laredo 4x4, Mrs. LUCDOG's DD.
Lots of parts not for sale, i'm a hoarder.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 09-07-2014, 06:26 PM   #6
CSP
Found in the stickies thread at the very top of the first page of this CJ forum.
http://www.jeepforum.com/forum/f8/of...thread-377983/
CSP is offline   Reply With Quote Quick reply to this message
304 , cj , engine
