Engine Problems, please help!! - JeepForum.com
post #1 of 8 Old 06-26-2003, 10:42 PM Thread Starter
Mastermind
Mastermind's Avatar
Red face Engine Problems, please help!!
Went for a little wheeling tonight... BIG mud pit, up to almost the top of the hood. The engine stalled coming out of the mud, so I tried to start it, and it wouldnt. I let it sit for maybe 5 minutes, then tried again. It was gurgling really bad trying to start, and finally did. Once it was started it felt like I had no control over the throttle at all. I let it idle for a couple minutes then revved it up. I let my foot off the gas, and it kept revving. So I killed the ignition, and started it back up again, idled fine. Revved it up, did the same thing. Killed it. So I let it idle for a few more minutes and had my friend pull me out to the road. Stuck it back in 2wd, unlocked the hubs, the usual, and went to drive home. It was fine for maybe a 1/4 mile, then it started going faster and faster. Killed it, started it and kept going. Finally dropped of my friend, and got home, but it did it like 10 times on the way home. It's not every time i accelerate, just sometimes.
Specs:
'84 CJ-7
256 I6 engine
Holley 4-bbl carb w/ vacuum secondaries, on an Offenhauser intake manifold
Things I've already checked:
Air cleaner, the element is pretty well smashed, and dirty, but seems otherwise fine.
Throttle cable is NOT sticking. Even if i sit there and pull the throttle arm with my hand with the truck idling, it'll still do it every now and then.
Oh, and when I pulled the air filter off, I looked in the carb, and there's real fine dirt every where, but it doesnt seem like its being sucked in.
Also, when I got the Jeep, there was no vacuum line hooked to the carb, and about a week ago I spliced the vacuum line and hooked it up. It still seems like the secondaries are not kicking in, because they are dry.
Please, if you can offer me ANY advice it would be greatly appreciated!!
'84 CJ7 258, Holley 4-bbl.
'97 BMW 318ti w/ S52 M3-Engine
Mastermind is offline
post #2 of 8 Old 06-26-2003, 11:15 PM
Jeep Daddy
Jeep Daddy's Avatar
Are you saying that you started the engine and with the hood opened you rev the engine at the carb linkage and even if you force it closed it still revs up faster? Or is this only happening when you operate the throttle from inside the cab? If it's the latter, then try working the gas with the air cleaner off and at the linkage under the hood. Rev it up and tell us what happens. If you got a bunch of mud under the hood you may have it all over the linkage or the return springs.
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #3 of 8 Old 06-26-2003, 11:19 PM Thread Starter
Mastermind
Mastermind's Avatar
Yes, even if I pull the carb linkage at the actual carb, it still does it. So I know it's not the cable.
post #4 of 8 Old 06-26-2003, 11:38 PM
Jeep Daddy
Jeep Daddy's Avatar
I'd pull the carb and check it out. Sounds like the butterflys are sticking or you got some crap stuck in the throat keeping it from closing all the way (sometimes)
post #5 of 8 Old 06-27-2003, 05:59 AM Thread Starter
Mastermind
Mastermind's Avatar
Will it hurt it to spray carb cleaner into the carb while its running?
Also, someone suggested that I run a bottle of seafoam through. Will this help also?
post #6 of 8 Old 06-27-2003, 06:59 AM
Jeep Daddy
Jeep Daddy's Avatar
No - keep it reved up and go for it.
[i]Also, someone suggested that I run a bottle of seafoam through. Will this help also? [/B]
Don't know about this. There are tank additives you can buy that are safe though.
post #7 of 8 Old 06-27-2003, 12:34 PM
Infedel
Distributor
Had similar problems when I got moisture in my distributor.
'84 CJ-7
AMC 258 Stroker
Centerforce II Clutch
1" Body Lift
1" Shackle Lift
33x12.5" SSR Tires
Painless Wiring, Stainless Steel Dash
Infedel is offline
post #8 of 8 Old 06-27-2003, 03:56 PM Thread Starter
Mastermind
Mastermind's Avatar
Ok, this morning before work, I replaced the air filter, and sprayed some carb cleaner in the carb. Everything seems to be back to normal now. Just one other problem, which is the idle. It seems to be higher than usual, but I'll just adjust that when i get time.
Thanks for the help guys!
Engine ID problems decker Jeep CJ Forum 3 04-16-2009 01:37 PM
78 cj7 engine problems amc 304 bandit1990 Jeep CJ Forum 1 07-05-2008 04:56 PM
Engine problems, please help my80cj5 Jeep CJ Forum 2 11-20-2006 07:53 PM
Looking at a CJ, has engine problems. CJ7RX7 Jeep CJ Forum 11 10-30-2006 05:09 PM
please help have engine problems bryans 86 Jeep CJ Forum 2 04-15-2006 05:40 AM
