Engine Lift Plates - JeepForum.com
post #1 of 6 Old 06-12-2011, 09:41 PM Thread Starter
MoC
Engine Lift Plates
Looking ahead to when I pull the 360 out of the waggy...
Every engine I have pulled in the past I have done with a chain with hooks placed under the motor mounts. Never had any problem doing it just does not come out / in level all the time. I was thinking about buying a lift plate from advanced, under $20 I think.
Has anyone ever ran in to problems using one?? I see them all over the place, in stores on tv, but somehow lifting the engine by the manifold and 4 bolts sounds like a bad idea. Again I have seen it done many many times just wondering if anyone has had any bad experiences using on. Stock manifold BTW.
MoC is offline
post #2 of 6 Old 06-13-2011, 01:08 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
I read an article in Hot Rod or Car Craft about them, how even in an aluminum intake the 4 bolts are large enough to handle an engine. I personally like to use a bolt in the front and rear of the opposite head with a chain attached to it. On 4 cyl engines i just find an attachment point and go with it. My 258, I'll have to lookto see how to attach to it - I'll let you know after this next week.
Rick
Cutlass327 is offline
post #3 of 6 Old 06-13-2011, 06:16 AM
fuzz401
1978 CJ7
as long as the intake bolt are good no problem - I have used them a lot
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #4 of 6 Old 06-13-2011, 07:57 AM
molawnboy
1983 CJ7
I pulled a chevy motor with TBI and it only had 3 bolts. Easy to do. Built my own with scrap steel, drill press to bore out the holes, and presto motor outo.
Just beware, despite popular opinion, de-chroming your Jeep will not make it climb Everest, ford the Pacific, out run John Force, crawl up the side of the Grand Canyon, tow D-11 dozers out of the mud or even start every time for that matter. You need hi-steer for all that...
molawnboy is offline
post #5 of 6 Old 06-14-2011, 02:01 PM
billybob535
On the AMC V8 I just use the outer most bolt hole in the front of the passenger side head and the outermost bolt hole in the back of the drivers side head. It seems to pull pretty even and I don't have to pull the carb. I do suggest using a high grade chain. I got a new one 6' long from home depot for less than $10. Its rated for a 2800# load. I have seen cheap/old ones break and ruin peoples day.
billybob535 is offline
post #6 of 6 Old 06-14-2011, 02:52 PM
mopar408
1974 CJ5
And use the " motor lift" that all the FLAPS have w/ the threaded jobber that centers the assy.
Just don't trust 4 5/16 bolts and if it came loose, $#!+load full of broken parts/bones.
If it's good TO you, it's gotta be good FOR you....
mopar408 is offline
Need motor mount engine plates fabricated 258 mounts to 2002 4.0 whittlecj Jeep CJ Forum 23 11-30-2008 12:50 AM
Oil Pan, Engine Lift???????? Etchandy Jeep CJ Forum 39 01-20-2008 06:13 PM
Engine removal lift points atom73 Jeep CJ Forum 5 11-04-2007 01:46 PM
CJ7 engine lift, MML JeepTrick Jeep CJ Forum 2 01-03-2007 09:58 PM
vin plates where are they located? Magic2979 Jeep CJ Forum 5 08-02-2006 08:48 PM
