Engine I.D.ing - JeepForum.com
post #1 of 3 Old 05-16-2013, 08:06 AM Thread Starter
kjonesie
1983 CJ7
Engine I.D.ing
I bought this Jeep thinking it had a 304 (Vin number and P.O.). After tearing it down I discovered "360" stamped on the block. Is this a 360? Are there any other casting numbers on the engine that identifies where it came from?
kjonesie is offline
post #2 of 3 Old 05-16-2013, 08:59 AM
Pathkiller
1974 CJ5
All AMC V8's have the displacement cast on the block. If it says 360 it's a 360. The engine build date code on a V8 is on a small aluminum tag screwed to the valve cover. It won't tell you what vehicle it came in but will tell you the exact date of manufacture and original configuration (2bbl or 4bbl).
Pathkiller is offline
post #3 of 3 Old 05-16-2013, 04:28 PM Thread Starter
kjonesie
1983 CJ7
Ok thanks. Someone put a Dana 44 under it also. Narrower than the front by an inch or so. I was going to install a set of wide track axles I have and a automatic transmission. Make it a daily driver.
kjonesie is offline
