engine fault, dying when I push gas pedal.. - JeepForum.com
post #1 of 5 Old 05-29-2003, 11:29 AM Thread Starter
Popol
Popol's Avatar
Hello all.
This is more of an annoyance, but still id like to get it fixed.
The car is a 79 cj7 5.0 V8 auto, when I press the gas pedal hard, either from standstill or when moving at any speed, the engine stalls for a few seconds, then spurts into life...
If i just push the gas pedal about 20% of max travel the car works fine, but if i floor it the car stalls almost, (best way to describe it) if i keep my foot down and leave it there, then after a few seconds it starts to pickup and seems to gain momentum..
I am guessing its a blocked/dirty carburetor? but I am not sure, open to suggestions....
Popol is offline
post #2 of 5 Old 05-29-2003, 02:09 PM
mad_matt
How big a carb ya runnin? 5.0, as in ford? Does it do this at low rpm or also runnin down the interstate at 55 when you give er gas? Yer vaccume advance might be pinched causing the hesitation. Also might be a miss from things like bad spark pluggs or a dirty distributor. Dunno. But they would be a good place to start lookin.
'76 cj-7 on 35's
"What the hell do you mean they don't make banjo bolts anymore?!"
mad_matt is offline
post #3 of 5 Old 05-29-2003, 03:11 PM Thread Starter
Popol
Popol's Avatar
as to carb I must admit I havent had a chance to look yet been busy patching the car so the lights and stuff work, now getting around to looking more closely at the other faults.
5.0 as in Litres, I am not sure on the american sizes (im in spain) I guess that is 304 ?
It chokes with the pedal down from standing, and when driving at about 60 kph..
If i press my foot to a third of its travel, its finme and pulls ok, if i floor it my head shoots forward as the car literally takes a dive and then it starts to pickup the gas after about 3 or 4 seconds if i leave my foot down, if i take my foot straight off and reaplly again its fine to about a 3rd of its travel..
Popol is offline
post #4 of 5 Old 05-29-2003, 03:20 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
Sounds like the accelerator pump is bad - try to find a rebuild kit for the MC 2100 carb and it will cure the problem - it comes with a new power valve as well.
Steve
OldJeepguy is offline
post #5 of 5 Old 05-29-2003, 05:03 PM
possum398
Carb?
I have that same problem. My is caused by my carb. I have a 2bbl 500 cfm Holley. It is a good carb for the application, but mine is in need of a rebuild.
possum398 is offline
engine trouble, water in oil, and dying CopenhageCowboy Jeep CJ Forum 4 11-01-2009 07:54 PM
push rod and rocker jeepcj304 Jeep CJ Forum 9 03-04-2008 07:01 AM
Is my engine dying???? webejpn01 Jeep CJ Forum 10 01-15-2007 11:47 AM
First dying engine post this week... 143hc Jeep CJ Forum 8 11-20-2005 05:51 AM
258 engine bent push rod dtrimble Jeep CJ Forum 5 07-15-2004 07:58 PM
