engine drop in checklist - JeepForum.com
post #1 of 14 Old 11-15-2012, 10:11 PM Thread Starter
8pitcher
8pitcher's Avatar
im getting ready to drop in my 304 into my cj5 and i am looking for kind of a checklist if anyone has one or any suggestions please post them up.
8pitcher is offline
post #2 of 14 Old 11-15-2012, 10:57 PM
82JeepCJ7
1982 CJ7
I have a white board in my shop. As I thought of stuff I wrote them down. As they are done, I cross them off with a single line (so I can still read them.)
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #3 of 14 Old 11-15-2012, 11:01 PM Thread Starter
8pitcher
8pitcher's Avatar
But what were some of these things on your board? I really need a guide of what to do because I don't know what I'm Doin.
8pitcher is offline
post #4 of 14 Old 11-16-2012, 06:20 AM
davbytrace
1979 CJ7
Is this a swap from something different, or just a replacement? Depending on your answer, just checklist is very different.
davbytrace is offline
post #5 of 14 Old 11-16-2012, 06:40 AM Thread Starter
8pitcher
8pitcher's Avatar
Just a rebuild.
This is how my ch sits now.
8pitcher is offline
post #6 of 14 Old 11-16-2012, 09:58 AM
row684
what is your starting point on the motor and tranny?
row684 is offline
post #7 of 14 Old 11-16-2012, 10:00 AM Thread Starter
8pitcher
8pitcher's Avatar
What do you mean?
8pitcher is offline
post #8 of 14 Old 11-16-2012, 10:03 AM
85LaredoCJ7
Green drivetrain *check*
The Dude abides....
85LaredoCJ7 is offline
post #9 of 14 Old 11-16-2012, 10:09 AM Thread Starter
8pitcher
8pitcher's Avatar
Pretty isn't it?
8pitcher is offline
post #10 of 14 Old 11-16-2012, 11:09 AM
texasdave
texasdave's Avatar
1980 CJ7
If you go to any of the shop manuals it tells you how to remove the engines then it says install in reverse order. that would be a good place to start. If you are putiing the xmsn and engine in as a unit it will change slightly.
I go somethng like this:
1) New motor mounts ( I put them on the egine first then engine into frame.) Torque mounting nuts to spec.
2). Hook up fuel lines and use new filters.
3) Electrical system ( I notice you don't have one so this will come later.)
4.) Install radiator and hoses. Heater hose can be by passed unitl tub is installed.
5). Remove distributor and prime oil pump using a drill to turn the oil pump stem.
6). Check fluid levels.
7.) Connect grounds and ensure good ground.
8) recheck fluid levels before first crank.
texasdave is offline
post #11 of 14 Old 11-16-2012, 11:13 AM
jeepwhore
The only immediate things I can think of are:
-chain and hardware for physically lifting it into place
-extra set of hands to help line it up and lower it
-motor mounts
-mount fasteners
-some means of supporting the rear of the engine until you can get the transmission put back in.
Considering you're working with a bare frame there isn't a whole lot to consider......it's not like you'll be firing it up right after install.
Doesn't look like there are any fuel lines on the frame to connect? No tub in place so the grille can't be supported, ergo no radiator can be installed yet.....maybe you just need a chronological re-assembly list for the whole Jeep!
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #12 of 14 Old 11-16-2012, 11:56 AM Thread Starter
8pitcher
8pitcher's Avatar
-motor mounts
-mount fasteners
Nag engine first then the tub comes then wiring and stuff just looking for info on what others have done getting their engine in. It will be much easier for me to get the engine in then do the tub because I'm using a skid steer to drop in my engine because I have to carry it 50 ft or so across gravel to get it to my frame.
8pitcher is offline
post #13 of 14 Old 11-16-2012, 11:57 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
8,
If you've got an engine hoist, I'd consider attaching the clutch assembly, bell, and transmission, to the engine. Then hoist and set that all at once onto the motor mounts. As mentioned, be sure to support the back half under the tranny, so you don't twist the motor mounts. Then, I'd install the t-case, skid plate/tranny mount, and connect the driveshafts, in that order
From there, I'd consider installing all the stuff that will be easiest to get to without the tub in place, including fuel lines (supply and return), brake lines, e-brake, and exhaust system.
Hope this helps,
Matt
Matt1981CJ7 is offline
post #14 of 14 Old 11-16-2012, 12:02 PM Thread Starter
8pitcher
8pitcher's Avatar
Originally Posted by Matt1981CJ7
8,
Hope this helps,
Matt
Thanks Matt. I'm gettin in the engine and tranny then I will do driveshafts later as I need to get a custom size DC rear and front.
8pitcher is offline
