Engine dies with lights and Fans on - JeepForum.com
post #1 of 8 Old 11-04-2013, 01:18 PM Thread Starter
VaCJ79
1979 CJ7
I've been chasing down what keeps randomly killing my engine. I've ruled out vacuum issues.
If I turn everything on: single fan, radio, heater blower motor on to hi, the engine just dies. If found this out by waiting for the Jeep to heat up so the fans come on and then turning on other electrical things. Currently only have one fan running out of two, its cooled off here already.
The fans have a max draw of 30 amps each. I have a new 75 amp SI alternator and the battery is only a few years old.
Need Help figuring out how to fix this. Thanks
1979 CJ7 258 / 4.0 head / J20 power Steering / T150 Dana 20 / EMU YJ 2" lift / Custom front bumper
Looking for : Please PM, Carter 2 barrel Carb before you through it out
VaCJ79 is offline
post #2 of 8 Old 11-04-2013, 01:52 PM
ScroungerLee
I would suspect the new alternator isn't putting out the amperage it should be.
ScroungerLee is offline
post #3 of 8 Old 11-04-2013, 02:29 PM
2Xtreme
2Xtreme's Avatar
1979 CJ7
Does it die immediately, or eventually?
2Xtreme is offline
post #4 of 8 Old 11-04-2013, 04:39 PM Thread Starter
VaCJ79
1979 CJ7
If I have everything running, then flip the heat on to straight to hi, it dies right away just like if when I turn the ignition off. If I keep the rpms up to 1000, you can tell it wants to but doesn't...rpms flicker a little.
VaCJ79 is offline
post #5 of 8 Old 11-04-2013, 05:04 PM
benullman
1981 CJ7
time for a new alternator or larger one.
Our brush truck did the same thing till we replaced it with a generator alternator. If you had the light bar on and tried to pull a prime with the primer motor it would kill the entire truck. and that's a 351M 1979 F250
Ben
Originally Posted by Gregg79CJ7304 View Post
Great minds think alike, but so do serial killers......Thanks.
benullman is offline
post #6 of 8 Old 11-04-2013, 05:16 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
VaCJ79,
Do you have a multimeter?
Matt
Matt1981CJ7 is online now
post #7 of 8 Old 11-04-2013, 05:38 PM Thread Starter
VaCJ79
1979 CJ7
I do not but I have been meaning to pick one up.
VaCJ79 is offline
post #8 of 8 Old 11-04-2013, 05:59 PM
82JeepCJ7
1982 CJ7
Basically, what is happening, when you turn on a large amp draw, the ALT cannot keep up with the demand and voltage to the ignition system is cut to a point where the engine will not run.
I would look at your connections. Chances are your grounds from the battery to the engine block have either corrosion or oil/varnish on the block where the system cannot make a good ground. I'd replace the battery cables. Use a wire brush on a drill or grinder to clean the block area. Then spray with carb cleaner to get the gunk off.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
