Engine dies after about 10 minutes... Why? - JeepForum.com
post #1 of 6 Old 12-20-2009, 04:05 PM Thread Starter
Bic05
1977 CJ5
1977 CJ5 - 232
My Jeep will fire up and run, but after about 10 minutes of running (either sitting or driving) it dies and does not want to start. It has gas. When I get it started (have to pour gas in the carb) it only runs for about 15 seconds and then dies again. Fuel pump and fuel filter are new. If I wait a day or so and start it, it will run for about 10 minutes and die again. What is going on?
Bic05 is offline
post #2 of 6 Old 12-20-2009, 04:07 PM
jeepwhore
Get your ignition module tested. Located on the driver side inner fender below the windshield washer resevoir.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #3 of 6 Old 12-20-2009, 04:18 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
How many vacuum lines are plugged under your hood??? Unplug the vent line for the fuel tank. Having to pour fuel into the carb tells me it is a fuel issue not an ignition issue. The reason it runs for a few seconds is it is running off the fuel you dumped in the carb..
Another thing I experienced once was the crud in the fuel tank would build up on the pickup sock in the tank and shut the car down. After it sat a bit the crud would fall away and allow me to drive for a short distance until it did it again. Had to drop tank and clean it out before it'd be good to drive without worry.
Rick
Cutlass327 is offline
post #4 of 6 Old 12-20-2009, 04:25 PM
jeepwhore
Could be but the symptoms he describes sound exactly like a bad module. They will work fine until they heat up then crap out until they cool off after 20 or 30 minutes. Either way, two good places to start looking and two easy checks. Remove the vacuum line as suggested and if it still dies, unbolt the module from the fender and get it tested at your nearest parts store.
post #5 of 6 Old 12-20-2009, 04:37 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Quick test is leave the fuel cap off and driver for a bit.
Rick
post #6 of 6 Old 12-20-2009, 08:12 PM Thread Starter
Bic05
1977 CJ5
Thanks for the help. What is unplugging the vent line going to tell me? If I unplug the vent line and it still dies, it's something else?
Bic05 is offline
Engine runs for 30 seconds then dies.... HELP! dangjeep Jeep CJ Forum 9 10-22-2009 09:16 PM
Engine dies when it warms up Dad03 Jeep CJ Forum 3 05-07-2009 12:06 AM
Engine Dies.... elks96 Jeep CJ Forum 11 05-06-2009 11:13 AM
CJ engine dies occasionally... specops72 Jeep CJ Forum 15 03-06-2008 05:18 PM
82 CJ5 engine dies when stopping CeeJayFiver Jeep CJ Forum 6 05-30-2007 02:16 PM
