Engine cross roads - JeepForum.com
post #1 of 17 Old 10-08-2013, 10:05 PM Thread Starter
wsmutch
Engine cross roads
My hand is finally forced. I went for a short drive this afternoon and parked on the street. Later I came out and stated it up to spray some carb cleaner on the choke. I heard a fast knocking from the motor. The sound is like some one hammering on the block with a small hammer. It speeds up when I rev the motor. The motor has had a valve tick that came and went. Oil pressure was about 20-30 lb and it dropped down to nothing at idle after a long drive. It never burned oil and the temp ran on the cool side. I'm trying to decide what to do now. The block number indicates that it is not the original motor and dates to around 1979. I'm not a hard core off roader or speed demon, any more anyway. I like the 258, but I'm not sure if machining and a total rebuild wouldn't cost as much as a new re-manufactured motor that would include a warranty. I want to keep my T176 trany. I had hoped to milk this engine until next summer as I blew my jeep budget rebuilding my tranny. I'm not married to the original engine, but I need to decide a coarse of action. You guys have a lot of experience, and I'm sure many of you have faced this same situation.
wsmutch is offline
post #2 of 17 Old 10-09-2013, 06:12 AM
gmakra
I would go with a re manufactured crate motor for a couple of reasons one is the warranty and the other is that machine shops can be hit and miss on quality. The Jeep in line 6 is an easy engine to rebuild however there are some quirks about the engine that if the machinist is not aware of can cause you problems.
gmakra is offline
post #3 of 17 Old 10-09-2013, 06:19 AM
2Xtreme
2Xtreme's Avatar
1979 CJ7
Originally Posted by gmakra View Post
...however there are some quirks about the engine that if the machinist is not aware of can cause you problems.
Like?
2Xtreme is offline
post #4 of 17 Old 10-09-2013, 06:45 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I'm torn on this one...
I spent probably twice as much on my re-build (on parts and machining alone), than I would have on a crate engine. That stung a little.
With that said, I'd do it all over again. It was an incredible learning experience, and the satisfaction of rolling with an engine that you built yourself can't be beat. Plus you can spec your own parts, do custom modifications, and pay attention to details that are mostly overlooked with a crate engine.
Good luck,
Matt
Matt1981CJ7 is offline
post #5 of 17 Old 10-09-2013, 08:01 AM
swatson454
1983 CJ7
While a warranty sure sounds tantalizing, imagine the nightmare of having a failure, going round and round with the company, pulling the engine and shipping it to them and then trying to predict which excuse they'll use to blame you for the failure?
I think my money would go to a competent, local machine shop who will hopefully pay attention to details without the "assembly line" mentality.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #6 of 17 Old 10-09-2013, 08:30 AM
2Xtreme
2Xtreme's Avatar
1979 CJ7
I find this to be a timely post.
After a little more diagnosis, I think I will be at the same crossroads.
Interested to see what additional input members have.
2Xtreme is offline
post #7 of 17 Old 10-09-2013, 09:21 AM
CSP
If budget is a concern, it's not that hard to find a well running, used 258.
CSP is offline
post #8 of 17 Old 10-09-2013, 11:44 AM
Gigemags05
1980 CJ7
I went a little different route.
When I bought my jeep, the P.O. gave me a 1992 4.0 engine he was going to swap into the jeep. I knew absolutely nothing about engines, but with a little help I was able to completely rebuild the 4.0 for around $1k.
I know it isn't original, but I have fuel injection, more power, parts are easy to find, and I was able to take my time building the engine because the 4.2 was still running in the jeep, although really tired.
I was also able to sell my old engine for just under $600.
Gigemags05 is offline
post #9 of 17 Old 10-09-2013, 12:29 PM
Matt1981CJ7
1981 CJ7
I'd like to see a list of parts and the machining that you had done for that price.
With all due respect, I find it hard to believe that you "completely" rebuilt your engine for $1k, considering the average master rebuild kit goes for around $500, and the machining (including dipping, bead-blasting, boring and honing, 3-angled valve job, and head assembly) typically goes for at least $800-$1000 in labor, at least in my neck of the woods.
Add to that some new external components, like water pump, timing cover, alternator, starter, carb, ignition system, etc, etc....and it's damn easy to rack up $3-4K in costs, or more.
Matt
post #10 of 17 Old 10-09-2013, 12:58 PM
Gigemags05
1980 CJ7
rebuild kit: $400 using a 20% coupon
valve job: $70 at a local shop (different than machine shop I used)
decking, honing, blasting, etc. at local machine shop: right at $500 (not the cheapest I found either).
water pump, timing chain, alternator, coil, distributor, oil pump, thermostat housing, new sensors, belt, new radiator are all new or factory reconditioned but I wasn't including any of that in the price. I was talking about the actual engine. Those parts are very easily accessed (with the exception of the oil pump) and wouldn't be included in any engine purchase.
I had a new starter donated with the 4.0, no need for a carb (fuel injected), ignition system is not new (nor is it part of the engine).
I did all the disassembly and assembly work myself, painted the block myself, etc.
post #11 of 17 Old 10-09-2013, 01:11 PM
Dngrs1
1979 CJ7
In my limited experience of wrenching on my own vehicles (40 yrs.), I have learned one or two things about replacing engines.
If you rebuild the engine yourself, you are the only warranty. If it breaks, you fix it. This is also the least expensive route.
If you take your engine to a reputable machine shop, you have input into any special work you want done or parts you want installed. Unless you have the engine installed by an ASE certified mechanic, machine shops will only warranty the work THEY did if the engine fails. This can be hard to prove, sometimes.
Crate engines can be bought stock or customized. May not be warrantied unless installed by an ASE certified mechanic. You don't know the origin of the block or heads. Have the heads been resurfaced?, the cylinders bored or resleeved?, the crank journals bored with oversized bearings?
I have gone all three routes and personally I prefer the machine shop rebuilding my engine.
I would rather have a tool I don't need, than need a tool I don't have.
Dngrs1 is offline
post #12 of 17 Old 10-09-2013, 01:35 PM
jay-h
I went the reman route on my 258 YJ. I recommend it, a good reman shop has a lot of experience. Also you're facing less of a wait.
I did not want to do the swap myself, since my local mechanic is a Jasper dealer I went with that. As it turned out the replacement engine developed lifter troubles. Once my mechanic documented the issue they authorized full replacement (not just lifters and cam) ..they covered the full replacement cost.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #13 of 17 Old 10-09-2013, 01:36 PM
Matt1981CJ7
1981 CJ7
Well, that makes more sense. Thanks. I think most people would consider many of those items as necessary costs of a rebuild, especially those swapping a 6-banger for a V8.
Your point about those items not being included in a crate engine is valid.
Your machining cost are lot cheaper in Texas than around here.
Matt
post #14 of 17 Old 10-23-2013, 06:39 AM
2Xtreme
2Xtreme's Avatar
1979 CJ7
OP, where do you stand on your decision here?
I was all set to do my own rebuild (minus machining), but the lower cost of a crate motor sure would leave a lot of money on the table to be spent elsewhere....
2Xtreme is offline
post #15 of 17 Old 10-23-2013, 07:09 AM
Matt1981CJ7
1981 CJ7
BAWK BAWK BAWK.......
Matt
