Engine crooked? - JeepForum.com
post #1 of 3 Old 07-21-2007, 10:46 AM Thread Starter
bpal
Engine crooked?
I had bolted the 258 engine back in my CJ a couple of days ago and was putting the transmission and transfer case back in this morning and am having some alignment problems.
The drivetrain is skewed with the back end pointed to close to the drivers side so that the transmission mount does not line up with the holes in the skid plate. It is off by maybe 1.5".
I've tried to loosen all of the engine mounts including the brackets on the frame and the skid plate mounting bolts. The only way I can get it to match up is to use one of the non-centered holes on the drivers side frame bracket. It seems like it should work without having to do this.
Any other suggestions?
By the way its an 85 CJ and this is the same drivetrain that was previously installed in it. The new rubber engine mounts I had installed with bracket up on drivers side and bracket down on the passenger side (as it is on my 86).
'86 CJ-7 totaled
'85 CJ-7 frame off in progress
bpal is offline
post #2 of 3 Old 07-21-2007, 07:53 PM
gosupes
You didn't change the frame bracket locations, did you? One side (pass?) used the outside pair and the other side of the engine used the rear pair of holes. Going off memory, so might not be 100% correct.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
post #3 of 3 Old 07-22-2007, 10:07 AM Thread Starter
bpal
I got it finally to line up.
I just ended up loosening everything.
Bolted the skid plate to the transmission mounts first before bolting it to the frame.
And used the hoist to move everything around until it matched up.
I don't know what I would have done if I did not have the body off.
Oh well, back to paint and body work.
'86 CJ-7 totaled
bpal is offline
Crooked Steering Wheel calcallender Jeep CJ Forum 9 10-03-2007 11:28 AM
axle crooked after different front springs 79cherokee Jeep CJ Forum 2 07-08-2007 09:39 PM
My CJ is sitting crooked...Help!!! dredfive Jeep CJ Forum 27 09-15-2004 05:38 PM
MY CJ7's Frame is Slightly Crooked??? Jeep256 Jeep CJ Forum 9 06-24-2004 10:41 AM
What would cause my headers to be crooked? motoxxxguy Jeep CJ Forum 5 07-24-2003 06:19 PM
