Engine coolant temperature sensor location - JeepForum.com
post #1 of 6 Old 04-17-2012, 02:31 PM Thread Starter
mminorhsd
1979 CJ7
I'm a newbie to the forum and to jeep ownership. I have a 1979 CJ7, with a 258 cubic inch inline 6 engine. I purchased this as a restoration project.
It appears that someone removed/cut every wire from the gauges except the oil pressure gauge. I want to get all of the gauges working eventually. I'm concentrating on the temperature and fuel gauges. I have seen several really good trouble shooting forums on here. However, I have a very simple question. Where is the engine coolant temperature sensor located on the engine. I see something that appears to be installed in the head, under the left side of the carb as you look at the engine from the front of the jeep. It appears to be a copper tube that someone cut with diagonal cutters. Could this be what I am looking for. Nothing on the engine other than the oil pressure unit has any wires attached.
Mike
1979 CJ 7, 258 cubic inch restoration project.
mminorhsd is offline
post #2 of 6 Old 04-17-2012, 02:48 PM
davbytrace
1979 CJ7
If my memory serves me correct, when I had a 258 IL6, it was next to the firewall.
As you are sitting in the jeep, it is on the left side of the engine, at the back. You will see a 3/8 or 7/16 thread brass fitting sticking up out of the head with 1/8 inch bolt threads on it. Thats where the coolant temp sensor wire goes. I think the wire is purple.
davbytrace is offline
post #3 of 6 Old 04-17-2012, 02:55 PM
CoAce
1977 CJ7
On my 77 258 it is in the exact location as above.
Top of head next to valve cover. Next to firewall driver side.
CoAce is offline
post #4 of 6 Old 04-18-2012, 07:47 AM Thread Starter
mminorhsd
1979 CJ7
Thanks!
I found it right where you said. It is covered in dried mud and oil...and with no wire. That made it hard to recognize. I will order a new one and add a wire to the gauge. And keep my fingers crossed that will fix it. If not on to more trouble shooting.
Mike
post #5 of 6 Old 01-21-2013, 09:16 PM
st0rckz84GDub
Gauges
I know this is an old thread, but I just stumbled upon it... just a little FYI in case you havent figured it out yet, the fuel gauge, water temp gauge, and ammeter will ALL stop working IF the CVR is bad. BJ's Offroad sells a replacement gauge w/ the CVR for under $30 and it will usually fix this problem...
st0rckz84GDub is offline
post #6 of 6 Old 01-21-2013, 09:26 PM
BagusJeep
1981 CJ7
stork84dubya, is that your real name?
Welcome to the Forum, if you fill out your Profile it would be an asset.
CVR - XXX Voltage Regulator?
There is a voltage regulator in the fuel gauge, see John Strenk's excellent write ups on this. Without it the fuel sender is toasted but as far as I am aware it does not feed the ammeter. I may be wrong, mine has a voltmeter.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
coolant , sensor , temperature
Coolant Temperature Switch for 1982 CJ7 Bigjonh Jeep CJ Forum 31 08-10-2014 03:23 PM
Coolant Temperature switch FamousJerry Jeep CJ Forum 2 11-30-2010 01:28 PM
coolant temp sensor location albinoplatypus Jeep CJ Forum 0 07-18-2010 07:34 AM
Coolant temperature sensor location? mmerlina Jeep CJ Forum 5 03-02-2008 09:39 AM
CTO (coolant Temperature overide) Switch twmattox Jeep CJ Forum 1 11-03-2004 11:45 AM
