Engine Compartment Wiring ID Help Request - JeepForum.com
post #1 of 15 Old 06-24-2013, 01:11 PM Thread Starter
Mr. Boh
Got myself a new CJ and going over what the PO did in the engine compartment. Here is the overall view, showing the new Weber and reman engine:
Could not ID a few wires that did not connect to anything. B is coming off of the turn signal loom. Did not see any orange wires in that location on the wiring diagram.
I know the engine is a reman and the wiring from the coil to the solenoid does not look stock. Can some provide a pic of how it it supposed to look?
Mr. Boh is offline
post #2 of 15 Old 06-24-2013, 01:18 PM
walkerhoundvm
1981 CJ8
B looks like a harness for factory fogs. G is coming off the O2 sensor...is it possible that thing was injected at one point, because even A looks too new to be on a CJ.
walkerhoundvm is offline
post #3 of 15 Old 06-24-2013, 02:02 PM
LeePrather
1978 CJ5
Orange wiring typically ends up with lights. Dash wiring lights are orange. Are all your front lights working including your side markets? Could be extra or accessory...
LeePrather is offline
post #4 of 15 Old 06-24-2013, 02:04 PM
LeePrather
1978 CJ5
A or D look like possibly your backup switch on top of the transmission. If no neutral safety (automatic trans only), then backup switch would be 2 wires...do you have reverse lights?
post #5 of 15 Old 06-24-2013, 02:40 PM Thread Starter
Mr. Boh
Could be for B, my front bumper is drilled for the fog light tabs so its possible it had Marchal fogs at one point. I looked at other under hood pics of CJs with OEM fogs and there is a loom running in that area.
All lights are working as they should, headlight, tails, marker in both switch positions. Walker may be right that B is for OEM fog lights.
Haven't checked, but I will go and check now to see if they come on.
Mr. Boh is offline
post #6 of 15 Old 06-24-2013, 04:48 PM
walkerhoundvm
1981 CJ8
E is your oil pressure switch - it turns on circuits like your manifold heater via a relay and I think the choke components...
post #7 of 15 Old 06-24-2013, 08:39 PM
texasdave
texasdave's Avatar
1980 CJ7
B could also be your under hood light connection.
texasdave is offline
post #8 of 15 Old 06-25-2013, 03:15 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Note: Jeep harnesses had connection for all common accessories and engine combination like Foglights and Tachs and Automatics and 4cyl engines. If it wasn't used, it just wasn't connected.
A: Thermal Electric Switch in Aircleaner assembly. Used 84 on in CJ's
See #1 In this Picture:
B: Verified that Orange does run to fog lights on the front... Just checked the schematic...
C: Electric Choke on BBD.
D: Coolant temp Switch
E: Knock Sensor
F: Cant make it out. too Blurry. Is that a blue wire? If it's Violet then it's the Oil Pressure Sensor.
G: O2 Sensor
Should just be one wire from solenoid to coil. From "I" on solenoid to (+) on Coil.
Looks like cover is missing. I'll look to see if I have a picture.
Check this site out...
Jeep Adventures Under the hood
John Strenk is offline
post #9 of 15 Old 06-25-2013, 07:47 AM Thread Starter
Mr. Boh
John, thank you very very much, very insightful. I guess my next question is: Is everything that is disconnected fine disconnected? The PO did give me a box with the original Carter, air cleaner, and emissions related controls. So I have all that if something needs to get connected.
Here is a better pic of F. C, D, E and F are in the same loom. Is that loom supposed to run across the top of the valve cover and not along the back of the firewall?
Mr. Boh is offline
post #10 of 15 Old 06-25-2013, 08:21 AM
John Strenk
1976 CJ5
Not really sure how it's routed. Most of those connections are for the computer that looks like it's been bypassed....
Probably can remove whole computer harness. There are several posts on how to do that.
Still need to check on that blue wire, plug looks wrong for oil pressure.
I see you oil pressure sender and it has a violet wire attached so it's not oil.
I'll check my old harness and see if I can figure it out.
Were does it run? to that relay socket?
post #11 of 15 Old 06-27-2013, 08:56 AM Thread Starter
Mr. Boh
It is all a part of this harness with two connectors that are not connected to anything. The loom then splits into 2 with most going to a large flat connector and the rest going to the computer (which it is still plugged into). I'd really like to clean this engine compartment up as much as possible. I do have plans to convert it over the Mopar MPI so I don't want to get rid of anything that may be necessary for that.
Mr. Boh is offline
post #12 of 15 Old 06-27-2013, 09:30 AM
John Strenk
1976 CJ5
99% of that harness can disappear.
There is one wire needed for the manifold heater and electric choke, that you don't need for the MPFI setup.
It passes through a flat 6 pin connector to the e-choke. Jumper that wire past the 6 pin connector and you are good to go with any carb setup.
Other than the temp gauge sensor and oil pressure gauge sensor, I think the MPFI replaces everything else....
post #13 of 15 Old 06-27-2013, 10:48 AM
keith460
Jeep. There's Only One
keith460's Avatar
With the Weber carb, I would use your stock air cleaner assembly and remove the MCU (computer).
Some mods to the engine wiring harness will need to changed if the computer harness is removed for your model year. It involves the electric choke, some ignition, and maybe the oil pressure switch but don't remember.
You will have a pile of wire as pictured below when it is all said and done.
1984 CJ-7 Renegade
keith460 is online now
post #14 of 15 Old 06-27-2013, 12:26 PM
John Strenk
1976 CJ5
Ah yes, it's bee so long I forgot about the two wires from the distributor sensor to the ICM...
post #15 of 15 Old 06-28-2013, 04:11 AM
86cj74.2L
86cj74.2L's Avatar
Yep, before he yanks the 'Puter out of the glove box he needs to follow the orange and purple wires coming from the distributor.
If they go to the firewall by the battery it needs nuttered first. If they go directly to the ICM on the drivers side inner fender your good to go spark wise.
86cj74.2L is offline
