Engine compartment pics - JeepForum.com
post #1 of 15 Old 09-01-2008, 11:41 PM Thread Starter
ryandelany
1976 CJ7
Anyone have pics of the engine compartment of a CJ7, preferably a 1976 with the 258 in it? I just picked up this Jeep and a few items don't look like they are in the right place, but I don't have anything to compare to. The items that most concern me are:
1. The fuel line going from the fuel pump to the carb
2. The hoses coming from the PCV valves (presumably to the carb) since mine are completely missing and the underside of my hood is covered in oil
3. Some of the wiring (PO wired distributor straight to a switch inside among other things)
4. Tubing from the windshield washer bottle/pump to the sprayer
Any pics and details would be greatly appreciated so I can get this engine compartment straightened out!
Ryan
ryandelany is offline
post #2 of 15 Old 09-02-2008, 04:35 AM
243
1978 FSJ Cherokee
One option is to scan Ebay and the web in search of "low mileage" and "collector" CJ's for sale and they often have pictures of unmolested Jeeps. Collins Brothers has a couple of low mileage 83-86 CJ-7's and CJ-8's that helped me out, they have on CJ-7 add that pretty much runs continuously on Ebay.
Dave's 78 Build
243 is offline
post #3 of 15 Old 09-02-2008, 09:03 AM Thread Starter
ryandelany
1976 CJ7
Thanks, I'll try that. I've been cruising around these forums and found some pics, but they aren't exactly my year/engine combination.
Someone out there must have a '76 with a 258 and a camera!
Ryan
post #4 of 15 Old 09-02-2008, 10:01 AM
243
1978 FSJ Cherokee
1983, original owner
1980
1979
Dave's 78 Build
243 is offline
post #5 of 15 Old 09-02-2008, 10:09 AM
jcal73
jcal73's Avatar
2015 JK Wrangler
GOOD JOB 243!!!
Jeff
Jeff
Our Jeep Links
jcal73 is offline
post #6 of 15 Old 09-02-2008, 10:51 AM Thread Starter
ryandelany
1976 CJ7
Awesome, thanks!
Looks like my fuel line from the fuel pump to the carb isn't too bad after all. Mine is all rubber which scared me a little, but it looks like the pre-80's used rubber instead of the hard lines so I guess I'll live with it.
Thanks again!
Ryan
post #7 of 15 Old 09-02-2008, 03:05 PM
Smtty58
Interesting pic of the 79, I always thought that style air cleaner wouldn't clear a brake booster. I'll keep that in mind when I upgrade, thanks.
90 YJ, 4.2, AX-15
86 K1500, 305, 700R4
Smtty58 is offline
post #8 of 15 Old 09-02-2008, 03:46 PM
Fjguercio
1978 CJ7
Originally Posted by ryandelany View Post
Awesome, thanks!
Looks like my fuel line from the fuel pump to the carb isn't too bad after all. Mine is all rubber which scared me a little, but it looks like the pre-80's used rubber instead of the hard lines so I guess I'll live with it.Thanks again!Ryan
The pics by 243 are very nice. Even has AIR, good thing for TX.
The stock would have solid fuel line from the fuel pump to the front/over of valve cover over to carb. The Carb has U shape hard line and the two are attached with a fuel filter that used two outputs. The Top Output of Filter goes back to the gas tank along the drivers frame. I have a pic of fuel line but do not have the recirculate fuel line. Maybe another will post.
A little caution I have the rubber line across my top valve cover. Mike Romain said he knew a guy that had car fire and insurance denied because of rubber line across the top of engine. FYI I respect M. Romain opinion.
Fred
1978 CJ7 with cast iron manifolds, Carter 1barrel carb, missing return fuel line to tank
1978 CJ7 with 2 barrel intake from 81 AMC Concord, Borla Header, 2 Barrel Carb.
If you have single barrel carb, 1981+ manifolds & carb would be good upgrade for your vintage also. $35 at up pull junk yard off AMC Cars, concord, eagle etc with the same engine, Power steering, pullies, more??
1978 After Rebuild & 2 Barrel Carb installed
Fjguercio is offline
post #9 of 15 Old 09-02-2008, 03:52 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Unless he hs steel engine mounts, That engine is going to torque over and slam that MC.
John Strenk is offline
post #10 of 15 Old 09-02-2008, 04:03 PM
John Strenk
1976 CJ5
Awesome, thanks!
Thanks again!
Ryan
My 76 has a steel line. Just like all of them should. I made some changes on mine but I'll grab a few of the fuel line.
post #11 of 15 Old 09-02-2008, 04:25 PM Thread Starter
ryandelany
1976 CJ7
Here's the pics of my engine. Notice the fuel hose is half hardline and half rubber, and way too much rubber at that. The filter is just sort of dangling between the intake manifold and the power steering reservoir (I think). Should I be worried about that? Should I shorten the rubber hose?
Additionally, notice the PCV valves. One has a breather on it with no hose, and the other is plugged with a bolt and hose clamp. I also have an aftermarket 4bbl Holley carb on there (not my choice) and don't know where the PCV valves should be hooked up.
Any info would be greatly appreciated. And yes, the jeep was originally yellow if you can see behind all the blowoff from the PCV valves.
Pics:
Ryan
post #12 of 15 Old 09-02-2008, 09:55 PM
kavephish
1981 CJ5
wow!! some of you have hideously clean engine compartments!!!
kavephish is offline
post #13 of 15 Old 09-03-2008, 02:25 AM
GPER
1979 CJ7
GPER is offline
post #14 of 15 Old 09-03-2008, 06:14 PM
Shrevmo
You have an aftermarket intake and header too. The distributator looks to be different too.
Its only money....I'll make more tomorrow!!
Shrevmo is offline
post #15 of 15 Old 09-08-2008, 12:18 AM
Bubba Ray
GPER explain mods please.
Bubba Ray is offline
how much garbage can I take out of a 1983 CJ-7 engine compartment podboy333 Jeep CJ Forum 12 05-27-2009 06:37 AM
Liner engine compartment?? mfeldman21 Jeep CJ Forum 13 02-24-2009 09:38 PM
258 engine compartment vent bdeck Jeep CJ Forum 3 06-24-2008 08:55 AM
oil leak in engine compartment BlueFalcon Jeep CJ Forum 11 06-11-2007 03:33 PM
how big 350 engine compartment? geepvehicles Jeep CJ Forum 1 11-02-2005 06:37 AM
