Engine casting date different from build date - JeepForum.com
post #1 of 8 Old 01-13-2014, 01:19 AM Thread Starter
sierraimage
1975 CJ5
Hello All,
Long time lurker of the site, finally joined. Was waiting to finish my chevy build to finally get to do a rebuilt of a jeep. Couldn't find a reasonably priced cj7 in Nevada so I opted for a a intermediate year 74..so I thought.
Here is where I need anyone to help make sense of something that does not make any sense at all.
The engine is a 232 i6. The block casting is 3224098 which is 1975.
The stamped build date code on the passenger side of the block is 711E27 which would be November 27th, 1974 when it rolled off the line as a 232??
So how could they put it together in the factory a year before the block was even poured from liquid iron?
I know one of you will have some insight.
And the VIN reads 1975 and the title reads 1974..uhg!!
Thanks for the help, one of many questions I will have throughout my build.
Thanks
sierraimage is offline
post #2 of 8 Old 01-13-2014, 11:12 AM
Dngrs1
1979 CJ7
Browsing this site http://www.webring.org/l/rd?ring=cj;...j_numbers.html I see where the '75-'79 258 also has the casting #3224098 (and 3227445). When I get home I will pop the hood of my '79 and see what it is. Y'know how this internet info is.
EDIT: Well, I did look and mine is 3227445.
I would rather have a tool I don't need, than need a tool I don't have.
Dngrs1 is offline
post #3 of 8 Old 01-13-2014, 06:47 PM Thread Starter
sierraimage
1975 CJ5
Indeed, I checked that site as well for much of my info. I am hoping for bad internet info in this case and that that cast code 3224098 was used prior to 1975. If they even used it in 1974 it would help me sleep at night.
I know the engine plants work on the calendar year as opposed to model years, but that would not change the fact that the cast is later than assembly.
Thanks for your help Dngrs1.
post #4 of 8 Old 01-13-2014, 07:21 PM
FLynes
1976 CJ5
Maybe the original engine blew and was replaced under warranty????
FWIW, my 1976 258 casting is 3224098, built November 7, 1975
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
Black Wellington Vinyl Bench Seats
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #5 of 8 Old 01-14-2014, 10:50 AM
CSP
Yep, there's always the chance that it's not the original engine in your 40yr old CJ.
CSP is offline
post #6 of 8 Old 01-14-2014, 11:08 AM Thread Starter
sierraimage
1975 CJ5
It could be of course but regardless of if it was replaced it still doesn't explain how the casting date is a year later then the assembly date which both are stamped on the engine block from the factory.
The assembly date is the date they made it a 232 added carb rolled off the line. It was stamped at that point in 1974 on the block as the assembly date. Not on the heads or other swappable part etc.
Just very strange space and time issue. Chicken before the egg.
post #7 of 8 Old 01-14-2014, 11:12 AM
CSP
You've certainly put more effort into this quandary than I would have. Chalk it up to bad info somewhere.
CSP is offline
post #8 of 8 Old 01-14-2014, 11:22 AM Thread Starter
sierraimage
1975 CJ5
Haha. Copy that. I think so as well.
Thanks for everyone's info.
Appreciate it.
Sierraimage.
