Engine Block Question? - JeepForum.com
post #1 of 9 Old 07-09-2013, 08:55 AM Thread Starter
cdt540
1983 CJ7
I have an '83 CJ7 with the 258. The engine is in need of a rebuild but the the block is chipped up by the water pump so went in search of another block to rebuild. I bought what I was told was an '83 engine sight unseen but it turns out to be a '79. I know I know but for a $100 it was worth the gamble. So I am trying to sort out my options, 1) rebuild the '79 as is 2) rebuild the '79 block and use the '83 head and manifolds or 3) attempt to get the chip repaired and rebuild the '83 as is (extra $150). I have lots of questions but the one I have now is what is connected to the fitting in the pic (red arrow, '79 block)? That fitting does not exist on my '83. The '83 looks like it has a plug where that connector would be but it is a little hard to get a clear view of it since it is still in the Jeep.
Thanks
Chris
'83 CJ7 (258 4spd)
Austin Tx
cdt540 is offline
post #2 of 9 Old 07-09-2013, 09:02 AM
CSP
Your head won't work with that block unless you enlarge the mounting holes on the head. Your head uses 7/16" bolts to attach it to the block, but that block requires 1/2" head bolts.
Fittings like that aren't deal breakers. Pull whatever fitting your existing block has and install it on the donor block if they aren't the same.
CSP is offline
post #3 of 9 Old 07-09-2013, 11:08 AM
Balvar24
1979 CJ7
That looks like a piece of a CTO. Why not use the 79 head and block?
"Work hard, rock hard, eat hard, sleep hard, grow big, wear glasses if you need 'em."
Balvar24 is offline
post #4 of 9 Old 07-09-2013, 03:09 PM Thread Starter
cdt540
1983 CJ7
My thought at this time is to just rebuild the '79 with the '79 head which is one of the reasons I am trying to figure out what goes to that connection because in its stock form it connects to something, I just don't to what or where. The only reason i considered the '83 head was because it was already configured for the aftermarket aluminum valve cover that is on the '83. The engine builder that i spoke to said he has drill out the 7/16 heads to put on the 1/2 stud blocks and was no big deal to do. I guess it is probably more straight forward to use the '79 head and have the mods done to it to accomidate the aluminum valve cover. I wasn't sure if there was any value in using the '83 head and manifolds over the '79 in general.
cdt540 is offline
post #5 of 9 Old 07-09-2013, 05:55 PM
CSP
Forget the aluminum valve cover and then you don't have any machine work.
That fitting, which is the CTO valve (or what's left of it), is specific to '79 emissions and other parts which that year uses. You won't use it, but do swap whatever fitting is in your existing block to this one.
CSP is offline
post #6 of 9 Old 07-10-2013, 08:17 AM Thread Starter
cdt540
1983 CJ7
Thanks all. I just got to save a few more coins$ and it is off to the machine shop.
Chris
cdt540 is offline
post #7 of 9 Old 07-10-2013, 02:01 PM
82JeepCJ7
1982 CJ7
Put a mechanical temp gauge in that spot.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #8 of 9 Old 07-10-2013, 06:04 PM
SCSEAJAYSEVEN
1978 CJ7
That is exactly what I did on my '78 258 block. The mechanical temp gauge works great, kinda coincides with the stock electrical gauge.
SCSEAJAYSEVEN is offline
post #9 of 9 Old 07-10-2013, 07:52 PM
james04si
james04si's Avatar
1977 CJ5
Yup, no big deal with the CTO valve. If you don't need it then have your machine shop just install a plug in its place or use it for a mechanical temp gage in its location. I would personally look into having them drill out your 83 head for 1/2" simply because of the aluminum valve cover. You will probably never find one for the other. The only manufacturer for it was Clifford and they stopped making them years ago and the 81+ won't fit because it is strait on one side and the early models had curves on both sides.
james04si is offline
