Engine Balancing - JeepForum.com
post #1 of 7 Old 12-31-2011, 01:45 PM Thread Starter
Donhrrs123
1983 CJ7
Engine Balancing
Hello, My recently purchased 1983 CJ7 has an inline 258 6 cylinder. I am a first time jeep owner and loving it. There is a vibration in the drivetrain somewhere and I suspect it is the motor. I will vibrate when in park or in neutral sitting still. Are these motors externally balanced?
Donhrrs123 is offline
post #2 of 7 Old 12-31-2011, 01:52 PM
VACJ7
VACJ7's Avatar
The 258 is internally balanced.
'84 CJ-7 |
VACJ7 is offline
post #3 of 7 Old 12-31-2011, 01:59 PM
nshefbuch
1982 CJ7
Check motor mounts and check tranny mounts especially the torque arm support off the tranny. If you have poly bushings instead of rubber it will vibrate more
CJ7/SOA /5.3LS/t18a/d300 clock/37"Pitbull Rockers/H1's/14 bolt detroit/d44 ARB 4.10 High Steer
nshefbuch is offline
post #4 of 7 Old 12-31-2011, 02:05 PM Thread Starter
Donhrrs123
1983 CJ7
What if the previous owner used a flywheel/flexplate from a 304? I has a torqueflight transmission. The previous owner said it was a 727, but I think it is most likely a 999.
post #5 of 7 Old 12-31-2011, 02:13 PM
VACJ7
VACJ7's Avatar
I believe the AMC v8's are all externally balanced, so if the flexplate is from a 304 it would not be neutral balanced. But I could be wrong. I have a TF999 bolted to my 258. Pan shape will tell you if it is a 727 or 999.
'84 CJ-7 |
VACJ7 is offline
post #6 of 7 Old 12-31-2011, 02:23 PM Thread Starter
Donhrrs123
1983 CJ7
Will do thanks.
post #7 of 7 Old 12-31-2011, 04:38 PM Thread Starter
Donhrrs123
1983 CJ7
Thanks, I suspected that may be the problem, nice motor on your profile pic!
vibration
Tire Balancing CJ Chet Jeep CJ Forum 15 01-23-2012 12:12 PM
225 v6 clutch balancing jwinsley Jeep CJ Forum 3 02-11-2011 10:12 AM
balancing tires/BB's wjr Jeep CJ Forum 10 08-30-2007 11:13 PM
Powder Balancing Raiderfanatic Jeep CJ Forum 6 09-18-2005 07:25 PM
AMC 304 balancing ? Cayjay Jeep CJ Forum 1 10-17-2001 05:35 PM
