Engine to Axles - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Engine to Axles
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenRight Offroad at CCOR! 706-207-4140Rough Country Lift Kits and Parts!
Unread 02-28-2012, 07:56 PM   #1
jdcj5
1979 CJ5
Engine to Axles
First Off let me say that, I know each of us has preferences and usage for a our jeep but….
I have less than a simple question… What is your perfect jeep drive train? From the engine to transmission to axles to wheel size with gear ratios…
jdcj5 is offline   Reply With Quote
Unread 02-28-2012, 09:34 PM   #2
JeepHammer
Running On Empty...
1973 CJ5
We are talking "Jeep" here and not just anything under the sun?
AMC 360, T-18b with granny low, Dana 300 twin sticked,
Dana 60 out back, HD Dana 44 up front with big brakes.
JeepHammer is offline   Reply With Quote
Unread 02-29-2012, 12:30 AM   #3
gearhead1985
obd1 4.7 stroker to a granny gear 4speed to nwf black box i to a d300 to a narrowed 66" wide d60 front and a full float ford 9" rear o wait what i am building
i want to put a pic here but the computer won't let me so here is the link
[url]http://i641.photobucket.com/albums/u...85/dnsjeep.jpg[/url]
gearhead1985 is offline   Reply With Quote
Unread 02-29-2012, 01:24 AM   #4
BagusJeep
1981 CJ7
AMC258ci, Carter BBD, T176, Dana 300, AMC20.
Yes, really. if I wanted a more powerful 4WD I would drive my Cherokee. If I wanted more off road ability the tractor would come out.
BagusJeep lives in Bali, the Land of Temples.
With a Jeep every prayer counts.
BAGUSJEEP HAS GONE TO THE DARK SIDE OF GUCCI KIT - WEBER 38DGMS NOW NESTLES WITHIN
BagusJeep is offline   Reply With Quote
Unread 02-29-2012, 05:11 AM   #5
jeepdaddy2000
1971 CJ5
You actually hit the problem here.
For mud, sand, rocks, and all around wheeling, including pavement trips, driving to your favorite fishing hole, Etc...my choices would be.
6 cyl engine, I prefer the Buick V6, but a lightly modded 258 is hard to beat.
Since we are dreaming, EFI.
Either a truck OD 5 speed, such as the NV 4500, or an auto such as the 700R4
300 t case (although a 20 would probably due just fine).
44's front and rear.
4.11 ratio.
Selectable lockers.
Power disk brakes.
Power steering.
4" lift
33" tires. Again, application drives tread patterns. perhaps something in a Wildcat tread.
Although I love the pre 72 CJ5's, a CJ7 platform would allow for a lot more wriggle room. The base is also a bit wider.
Simple, strong, functionable.
Now as you begin to pick your medium of choice to wheel in, these choices will move around a bit.
jeepdaddy2000 is offline   Reply With Quote
Unread 02-29-2012, 05:34 AM   #6
ejb
1983 CJ8
For a hunting jeep in Wi's northwoods a cj8 with a gm 350/700r, dana 300, ford 9" front and rear, 4.88 gears, 4" lift, 35" tires
ejb is offline   Reply With Quote
Unread 02-29-2012, 09:02 AM   #7
JeepHammer
Running On Empty...
1973 CJ5
GOOD CALL! CJ-8...
I was thinking what I could stuff under a CJ-5 or CJ-7...
If I could have "Anything Jeep",
CJ-8 With longer wheel base, better approach and departure angles under a CJ-8 body.
Since it's not a 'Rock Buggy' or 'Desert Racer' or 'Mud bogger',
I think fairly common axles would work, but being able to clear at least 37" tires would be a good deal...
Unread 02-29-2012, 09:05 AM   #8
RobsCrawlin7
**** it, lets do it
RobsCrawlin7's Avatar
i would say an amc 360 or 401, np435/t18 with granny low, d300 with 4:1 kit, and at least d44's if not 60's with ox lockers
'79 CJ7 PICS HERE specs in profile - SOLD
'01 TJ 4.7/NV3550, 4" lift 33's stroked
'98 Chili Pepper Red XJ Sport, 4.0, AX15, 4x4 3" lift, 31" AT's
'79 CJ7 stock, 304
Originally Posted by my_304_cj7 View Post
I used Marvel once before I took my Jeep out on the trails. I didn't get stuck all weekend so I guess it works.
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline   Reply With Quote
Unread 02-29-2012, 09:12 AM   #9
kickingprop
CJ8 with an LS6/4L60E/Atlas (or a beefed D300), TruHi9's front and rear with ARB's on 37" rubber....mmmmm.
If not that, then a QSB4.5T tuned and geared appropriately to pull stumps and sip fuel on the highway...
1985 CJ7 Project
Phase One : 5.3L Vortec/4L60E, Moser axles for AMC20, Twin Stick'd Dana300 - Completed
Phase Two: Bedliner, Rollcage, Seats, BESRK Rear Bumper w/ tire swing, Soft Top, and a few other goodies - Mostly Complete
Phase Three: Waggy 44 front, Scout D44 Rear, 4.56's, ARB's (F/R) SOA with YJ Springs, 35x12.50x15 BFG MT - Not Even Close to beginning
Also a mostly rust-free 1970 Scout 800A That I'll get to start working on someday...
Chrome won't get you home...BUT Rattle Can Black may just get you back"
kickingprop is online now   Reply With Quote
Unread 02-29-2012, 09:35 AM   #10
LT1CJ7
1983 CJ7
CJ8, LS9, 4L80E, 4 speed Atlas, Dynatrac Pro Rock 60's on 40's
LT1CJ7 is offline   Reply With Quote
Unread 02-29-2012, 09:54 AM   #11
JeepHammer
Running On Empty...
1973 CJ5
OK, what happened to 'JEEP'...
Unread 02-29-2012, 10:00 AM   #12
LT1CJ7
1983 CJ7
Well, I took it as Jeep/AMC installed the Iron Duke, So the LS9 & 4L80E is still within the GM family.
The Atlas is a common Jeep swap, And based off the D300.
And the 60's are based off Dana which was also fitted to our Jeeps.
Kind of a stretch though
Unread 02-29-2012, 10:24 AM   #13
jeepwhore
Nothing says JEEP more than a mish mash of parts from different manufacturers, no?
'84 CJ-7: 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, Yukon 1 pc axles, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rear aussie locker, twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline   Reply With Quote
Unread 02-29-2012, 10:29 AM   #14
AFRd_CJ5
1976 CJ5
For what I do, I'd keep the same type of setup I have.
large ci SBC, GM trans, 9" rear
If I had to keep an AMC drivetrain and do the same type of thing, I'd do..
401 stroked to whatever I could
th400
D44/D30
'76 CJ5
434 pump gas SBC with an NX/HVH plate system
th350/Coan 5,000 converter/Dana 300 tcase
Dana 30 front with 4.56's/Dana 44 rear with 4.88's
AFRd_CJ5 is offline   Reply With Quote
Unread 02-29-2012, 12:08 PM   #15
bbc
bbc's Avatar
JEEP = Just Everyone Else's Parts
bbc is offline   Reply With Quote
