engine acronym for belt replacement
| DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97- | GR8TOPS Introduces the Exogate HD Tire Carrier | Truck-Lite's New LED Headlamp Series |
#1 | |
A/C is air conditioning, P/S is power steering, etc.
What is A/P?? Also, whos belts do you prefer? OReilly's - Master Pro Napa's - own brand name AZ's - Drualast, Gatorbak, Valucraft Advance's - Dayco
Mike D. |
#2 |
Stormaggedon
I'm guessing "Air Pump" - pushes air into the exhaust stream. This helps clean up emissions by itself, and it also increases the efficiency of a catalytic converter.
He that would make his own liberty secure, must guard even his enemy from oppression; for if he violates this duty, he establishes a precedent that will reach to himself. --Thomas Paine We work together every damn day. --Jon Stewart Any gas can be a knockout gas, when you wrap a steel cylinder around it and beat someone with it. Low Output 4 Cylinder Jeep Club member #188 |
#3 |
Yep but only the earlier jeeps with early (72-73) smog equipment had them. anything with a computer did'nt have one
#4 |
Your 86 won't have a air pump as stated. I like Goodyear or Gates belts when I replace mine.
#5 |
Thanks fellas.
Im leaning toward the GY or Napa belts. havent hear pros or cons on either so i might have to go with Napa as they have a LLT warranty and only a $5-7 difference between the two.
Mike D. |
#6 |
If you can take your belts with you to the parts store, because over the years pulley sizes have changed. You may not get the right ones on the first try.
#7 |
ah, good to know! thx.
Mike D. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
