EMPI 32/36 vs Weber 32/36 rebuild kit - JeepForum.com
post #1 of 3 Old 04-13-2011, 01:56 PM Thread Starter
bfranklin
I have a 86 CJ7 that is stock except for the EMPI 32/36 carb and I have been lurking here for some time now and finding answers to most of my questions by searching, but I can't seem to find an answer to this question.
It is running pretty rough and the carb is pretty dirty looking, I have ordered everything to do the TFI ignition upgrade for a start but I'd like to rebuild the carb too.
Can I used a Weber 32/36 rebuild kit to rebuild the EMPI 32/36 and if not where can I find the EMPI rebuild kit? I have searched all over the net with no luck.
bfranklin is offline
post #2 of 3 Old 06-30-2013, 06:51 PM
33Strings
1987 YJ Wrangler
What did you end up doing. I'm in exactly the same situation with my 87' YJ.
33Strings is offline
post #3 of 3 Old 07-01-2013, 02:58 PM
uptillnow
uptillnow's Avatar
I have seen a few of these Chinese clones, the EMPI at least will tell you it is a clone and the gaskets seem to be very close. I would use the REDLINE rebuild kit part number 92.3237.05. They do not come with the power valve diaphragm, nor the choke pull-off diaphragm. PV # 57804.097, C-pull off #47407.093. These three part numbers will take care of the whole job.
I like the REDLINE rebuild kit as it gives float info, tuning specs that work and a "Viton" needle and seat.
UPTILLNOW
uptillnow is offline
86 CJ7 EMPI 32/36 Rebuild bfranklin Jeep CJ Forum 0 03-31-2011 11:53 AM
EMPI 32/36 vs. Weber 32/36 ChaseB Jeep CJ Forum 357 01-04-2011 06:11 PM
Empi 32/36 carb tune/rebuild info needed Jon In Tucson Jeep CJ Forum 3 08-20-2008 08:35 PM
Carburetor Upgrade: EMPI EPC 32/36 vs Weber K551 CJfive Jeep CJ Forum 8 07-04-2008 10:20 PM
MC2100 vs Weber vs EMPI BUGS Jeep CJ Forum 11 09-04-2006 07:35 AM
